SOURCE: frigidaire compact 30 elec. stove.
Does yours have the timer/clock thing that stands at the rear left of the stove? If so, make sure the far right dial is set at Manual. I had a repair person come out once (luckily it was someone I knew who didn't charge me) because my oven quit working. He turned the dial to manual and presto! :)
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
SOURCE: Oven Control Guide for Frigidaire Oven needed
Go to managemylife.com and type in your model number under the "Manuals" link. Your owner's and installation manuals are both listed in a .pdf (Adobe) format that you can download or print for FREE. Hope this helps.
SOURCE: I have frigidaire slide-in stove
Most likely it's the clock/timer board that has to be replaced.
Testimonial: "thanks. Can I replace it myself??"
