Set clock on computer - Computers & Internet
    New Friend:
    Problem Solver:
  • 7 Answers
  1. Press the Windows key on your keyboard to display the taskbar if it isn't visible.The Windows key has the Windows logo on it.
  2. Right-click the Date/Time display on the taskbar and then choose Adjust Date/Time from the shortcut menu.
    The Date and Time dialog box appears.
  3. Click the Change Date and Time button.
    The Date and Time Settings dialog box appears.
  4. Enter a new time in the Time field.
    You can also use the up and down arrows next to that field to change the time.
  5. If you wish, click on a new date in the calendar display and then click OK.
    You can also change the time zone, if necessary.
  6. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
    If you don't want your computer to adjust for Daylight Saving Time, click Change Time Zone and click the Automatically Adjust Clock for Daylight Saving Time check box to turn this feature off.
  7. Click the Change Date and Time button.
  8. Enter a new time in the Time field.
  9. If you wish, click on a new date in the calendar display and then click OK.
  10. Click the Change Time Zone button, choose another option from the Time Zone drop-down list, and click OK.
Posted on Jan 20, 2017
SOURCE:
Ocsp let me in says date can you heip
your computers clock is not synchronized with the world clock. go to your clock setting and synchronize, then adjust for location. should work after that
Jan 01, 2014 | Office Equipment & Supplies
Set computer clock three hours later
Hi buffaloman...
To set your computer clock go to the time in the bottom right hand corner of your desktop screen.
Left click on the clock and a window will open, you will then click on "Date/Time Properties" and it will let you change the time of your computer clock.
Please take time to rate me
Sep 02, 2011 | Dell Dimension 2400 PC Desktop
How do i set a radio controlled clock seth thomas hd 1688
  • Place your Seth Thomas atomic clock face-down on a table or desk and locate a series of buttons labeled "PST," "MST," "CST" and "EST" on the back of the clock. Press the appropriate button to set the time zone.
  • 2
    Turn your attention to the small lithium battery-powered digital clock display on the back of your clock. With the correct time zone set, the digital display should accurately reflect the current local time.
  • 3
    Locate the AA battery compartment on the back of your clock. Put two new AA batteries into your clock's battery compartment.
  • 4
    Set the "Mode" switch on the back of your Seth Thomas atomic clock to "Run." Wait for it to adjust to the correct time. The automatic time-adjustment process can take up to 45 minutes, but is usually completed much sooner.
  • Read more: How to Set a Seth Thomas Atomic Clock ' eHow.com http://www.ehow.com/how_6120534_set-seth-thomas-atomic-clock.html#ixzz1GyAcVHP2 hope this helps you
    Mar 17, 2011 | Seth Thomas Radio Controlled Wall Clock -...
    How to set the clock on my computer
    Double click the clock down in the right lower corner click the middle tab and select your correct time zone. The computer should set the time automatically from here on out
    Apr 05, 2010 | Dell Inspiron 530s Desktop Computer...
    My acer monitor p244w has a clock setting on the menu.--what is this clock setting for?
    The "clock" refers to the internal oscillator clock circuitry that is responsible for the generation of the video signals. It is NOT used to set the time on the monitor. It is used to make adjustments to how the display looks, usually stretching/shrinking the horizontal width.
    Dec 30, 2009 | Acer Computers & Internet
    Can't set clock
    This clock sets itself from a radio signal broadcast by a US govenerment agency in Denver area. If it doesn't set in the first few minutes of installing the batteries, set it outside (shelted from rain/weather). If you are in an area with a lot of buildings or radio antennas, you many have to set it out over night. My clock set by the radio signal will only pick up the signal at night.
    You only have to set the time zone on this clock - it is supposed to pick up the signal and set itself.
    The cool thing about your clock is that you can record your weather history to your computer. Software is available from...
    http://www.hidekielectronics.us/WeatherCaptureAdvanceSetupV1-1f.zip
    The password to activate the software is HidekiWeatherCapture
    You can also go to their web page.
    http://www.hidekielectronics.us/Support.html for direct software download and more info.
    Nov 21, 2009 | Honeywell RC182WR Atomic Alarm Clock - Red
    Computer clock in not working properly
    Where are you setting the time?
    Try setting up from your BIOS settings.
    Jul 31, 2009 | Computers & Internet
    Sart up problem. I have an ABIT BE7/BE7-RAID Motherboard. On start up the computer started to request I press F1 to continue. The clock was also wrong. I put in a new battery, set the clock and hoped all...
    Yes! Re-install your Operating System (windows?). When all is well starting the computer will not require manual intervention. The clock is automatically set on almost all OS's.
    Jun 24, 2009 | Abit BE7-RAID Motherboard
    Will not let me change time setting
    I just disconnected from the computer and manualy went through change preferences arrows until I got to set clock. I was then able to set clock. Thanks
    Nov 19, 2008 | Tomtom ONE GPS Receiver
    Computer clock
    Not sure if this will help as my previous experience is that the clock starts at 12:00 each time it is started up.
    In my case it was a flat computer battery that keeps the BIOS active when shut down, hence it was losing all it's settings each time it was shut down.
    Note: This does not explain the looping, so this answer may be one "just to try" if no other answers come up.
    Apr 07, 2008 | Compaq Presario 700 470024-192 Notebook
    Open Questions:
    KASPERSKY CUstOmEr care pHone ~+18OO8-O31O69 NuMbEr u.s.a-24/7 Usa KASPERSKY USA phone number is ranked #2 out of 2 because 7,728 KASPERSKY USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach the KASPERSKY USA Customer care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, KASPERSKY USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. KASPERSKY USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact KASPERSKY USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling KASPERSKY USA Calling KASPERSKY USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from KASPERSKY USA Customer care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with KASPERSKY USA's Customer care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare KASPERSKY USA's phone numbers against each other. Contacting KASPERSKY USA in General While I8OO8O31O69 is KASPERSKY USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach KASPERSKY USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact KASPERSKY USA.
    Oct 17, 2019 | Best Computers & Internet
    Computers & Internet Logo
    97 people viewed this question
    Ekse
    Alun Cox
