The dishwasher counts down to 1, then just keeps running. When I open the door, water is still going and suds fill the bottom of the dishwasher. When I close it again and press the start button, it goes to 13, then counts down to 1 and keeps running again. The other day it was reading 58 minutes left in the cycle. When I looked a few minutes later, it was 74 minutes. A time or two before, it stuck on 1 but then operated correctly for a few days until today. Got the same problem. Display stuck at 1.I checked the drain pump, was ok and resoldered one relay pin on the control board. Problem did remain.I got a glance at a Bosch repair manual. If this is error code "1" it points to the Aqua Level sensor "Sensotronic Fault" . That part costs around $37.00 plus S&H. Can I check the sensor with an Ohmmeter? I do not have the electrical diagram.Uwe
You have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
I had the exact same problem as UweB. I just changed out my board last night. Only $136 with a lifetime warrenty on the board. I did it myself and I am a female, so if I can do it, you can! The dishwasher works like a charm now!! Thank you chris72 for posting the solution!!!!
I have the exact same problem on my Bosch dishwasher (model SHU68067C). Bought it brand new in 2001 and in Jan. of 2005 this problem first occurred. The repairman came out and replaced the timer. Yesterday (Nov. 19, 2007), the same fault appeared as described above. I guess it is a timer that is kaput again and I will call another repairman. These sure do seem to be a problem.
SMY
I too have the exact same problem. We bought the dishwasher new in 1999 and the first time it did this was about 2003. Now it is doing it again. It also leaves a white filmy residue on anything dark and plastic. I need to call a repair person again, but am getting fed up.
Me too....Exactly the same problem. No fixes yet. Help?
Same problem. Does anyone know what the problem is?> I changed my control pannel 2x still does it. Help please.
I have the same problem, the repair man told me that's how it's supposed to work, but I don't believe him.
I have the same problem - sticking on 1 as well as only letting me do a 2H hold cycle. This is obviiously a major default in design - anyone interested in class action lawsuit for all our trouble???
We have the same problem. The machine ran forever on the last minute. The problem was the burned thru spot on the control board. We just learned that Bosch has a recall for other models for what seems to be the same issue. Why is this model not included?
Same thing, in addition the drying cycle just simply never goes on. Plus it appears the washer is not as warm as it used to be.
OK where do your fine the repair manual on how to replace the board
Suddenly I have the same problem. Where can I get a look at the Bosch repair manual. Also when I look up the control board part number it tells me it's not compatiable with my model (SHU5315UC/U11)
