Device works as it has been set before breaking. The P0003 is set to 3 but I can't change any of the parameters. I can't try factory reset as P0010 would need to be set on 30 in order to do it. I have changed the panel in case it would be broken. Same problem accured to 2 of them around the same time so is it possible their internal memory is full?
SOURCE: Hidden BIOS in Phoenix 3a23 (for Packard Bell Easynote A7718 laptop)
You can try pressing F11 at POST, that is the hidden BIOS key for a lot of crippled motheroards.
SOURCE: need to reset to factory setting how do i do it
i put internet explorer8 on instead of 7 and it seems to have cured the problem
SOURCE: I need to factory reset a Siemens AP2620
If there is no tiny push button on the outside of the box then the only way to reset it is loging into it.
If you can find the ipddress range of the non-working vlan that the AP is in you can change your computer ip address to one in that range and then access the router with it's ipaddress.
Once you get in you can use these steps to reset it:
a. Click the Wireless Controller button to open the Wireless Controller
Configuration screen.
b. In the navigation pane, click System Maintenance.
c. Click the Reset database to factory default and reboot button.
d. Click the Apply button.
This will reset the database and cause the controller to reboot.
Regards
SOURCE: Check Engine code P0010
code 0010--camshaft position actuator circuit bank 1-- check for a faulty oil control valve(ocv)** short in ocv/solenoid valve**open short v v t/vct circuit
SOURCE: internal memory full
i have this same problem i even tried formatting my memory card and my camera and it still wont recognize the card i inserted
