Microwave Ovens Logo
Posted on Jul 22, 2009
Microwave stopped heating
Kenmore model 721.80019401 microwave stopped heating. It was working well and all of sudden, it stopped heating. Everything else works on the microwave.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 24, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
428
Points
I had the same oven for one and a half years and had the same problem. Had the sears repairman come out and he said the magnetron burned out and needed replacing for $285. It was never under warranty with the warranty that came with oven. I couldn't believe it! We had an independent repairman look at it and he found a design flaw that causes the magnetron to blow. If you replace the matnetron (megnatron?) it will work for awhile, maybe, but then just need to be replaced again. It's cheaper to buy a new microwave. In fact, I got out our old microwave that's over 20 yrs. old and still works--just isn't as fast and as new ovens. Good luck!
Kenmore microwave model 7210413500 suddenly stopped heating. What are the steps I might take to troubleshoot and diagnose the probelem. Is there another microwave that can replace this model in the s
Model nimber is blocked out for some reason. But dont try to repair a microwave unless you understand how to work with high voltages. The voltages you are dealing with here are lethal. You must discharge the capacitor before any work can be done. Generally only two parts are do most of the failures, the diodes an the large capacitor. If you do not have the proper gear to test leave it alone. The cost to repair is usually runs higher than the cost of a new microwave.
Kenmore microwave 721 85032010 will turn on but won't heat or spin
Chances are that is just a defective top or bottom door switch or its mount.
See our help file on door switches here.
Also, that model number does not show up as a valid US Kenmore model.
Please check the tag in the cooking cavity or elsewhere n the oven and let us know if you need further help.
1helpful
Our Kenmore microwave oven recently stopped heating. The lights, turning plate and controls all work but with no cooking is occurring. The last time I attempted to heat something up I heard a cracking...
The most likely cause is a bad magnetron, "heats food" the other two possibilities are the high voltage capacitor and diode. The cost to repair will a approach a new microwave oven.
My Kenmore Microwave, only a couple of years old, suddenly stopped heating. Everything else works fine. Model # 721.63242300
read the info on the below link, it was posted by me;
http://www.fixya.com/support/r7088553-microwave_oven_not_heat_hear_loud
Good luck.
Microwave not heating anything? everything else work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fgshg
Our kenmore microwave stop heating.. Everything works well but it just stop heating last night after l cleaned it.. did I do anything to it??
heatman101
78g
2answers
MICROWAVE NOT HEATING
Most likely you have a magnetron problem. Easy to replace (DYI) but make sure the high voltage capacitor is fully discharged first against the case.
Microwave oven suddenly stopped working, no display,not outlet
Hi, you must check the inside fuse. If is burned out, please consider that something happened, you must check further beyond to find the causes.
2answers
Kenmore elite microwave touch screen stopped working
Same thing happened to us. We just came back from Sears, where we bought another. Just for giggles, my wife suggested unplugging the old one and plugging it back in again. It works now. New one's going back to the store.
1helpful
2answers
Everything works except it doesn't heat anything
no, just 1 main fuse for everything. there are temp safety devices though, and door closed safety switches. Most likely failure though is the magnatron.
Top Kenmore Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
