SOURCE: Forerunner 205 wont turn on
"To power the unit back on, press the "Mode" and "Reset" buttons at the same time. Let go of those two buttons, press the power button, and the unit will turn back on."
If the unit is no longer displaying maps or lap data in the PC downloaded history ....perform a reset (as above) AFTER deleting all the Garmin HISTORY. This is done on the unit by navigating through HISTORY to "DELETE ALL" ---> now perform a soft reset.
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
SOURCE: My Nokia 2610 won't turn on, even after holding
try removing the battery for 30 seconds, put it back and switch it on, sometimes it resets the phone good luck
SOURCE: Plugged it into my computer, now wont even turn on!
HI,
TURN IT ON WHILE ITS CHARGING WITH COMPUTER,SOME TIME THERE WILL BE STROKING ON PROLEM..
TNKS
RABBANEES
SOURCE: phone turns itself off
yeah and I've heard rummors of a recall. but when my parents went up there to get a new one they told me "its been dropped several times" after going to the backroom for twenty minutes.
Aparently I've been "downloading things" which is **** because I havent, and in the end they kicked my parents out of the store, claiming there was no recall. Kricket, screw you.
You should just call the moterola company, it happens to alot of people.
