Replaced batteries, got a spark upon connecting (at the battery connection, nothing would turn on. Plugged in the unit, got sparks behind the panel which holds the control buttons. Disconnected everything. Anyone do repairs on this ups?
SOURCE: Powerware 9120. 1500i UPS
You can download the manual and other literature at
http://www.powerware.com/EMEA/UPS/9120_info.asp
The contacts for support in India are found at
http://www.powerware.com/India/Service_Support/IN_Office_Contact.asp
They offer a battery monitoring software package, at
http://www.powerware.com/India/Service_Support/IN_Battery_Services.asp
You can email support at http://www.powerware.com/pp/Check.asp?key=code1
Good luck
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
SOURCE: cannot connect the negative battery terminal without spark or starter turning over
You will need new igniton cylinder. Sounds like you have a short in the cylinder.
SOURCE: 4020 w/ 24v system sparks when the battery is connected
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
SOURCE: Rough idle
sound slike you may have unplugged or disconnected somethine else or the spark plug you put in is bad or inpropper gap
