Question about Razor Cycling
Razor pocket rocket pr200 turns on but dont run what else do I do I buy more parts it still don't work
The off and on switch lights up but will not start.
Posted on Dec 05, 2018
SOURCE:
  • 3567 Answers
SOURCE: i cant get my pocket rocket to run
Try www.repairmanuals.com
Also Google " service manuals suzuki "
You didn't say what problem you are having with the bike.
Posted on Apr 04, 2009
  • 3567 Answers
SOURCE: pocket rocket wont start
The problem will be gummed up carbs or injectors which ever your bikes have.
Posted on Jun 30, 2009
SOURCE: i got a razor pocket rocket and my back wheel blew
Replacing the rear tire is a real nightmare.....you are much better off purchasing the entire rear wheel assembly which you can do from the Australian distributors Funtastic for only about $10-$15 more than if you just bought the tire.
To replace the tire you need to use a bench vice which a couple of bolts clamped into it to hold the hub in place.....you then need to remove the sprocket assembly which is a reverse thread......i had to use a hammer and a large flat head screw driver wrapped in a rag so as not to tear up the teeth.
Once you've loosened the sprocket assembly you have to undo the bolts the hold the two sides of the wheel together and the tire will come right off.
All of this would be totally unecessary if they used a tire that you could remove just like any other mini motorcycle tire.
They don;t and so it is what it is.
As I said, next time just buy the whole assemble and then it's very straight forward.
Hope that helps!
Posted on Feb 20, 2010
SOURCE: i tried to fix the pull start on my pocket rocket
Hey Google ur question about the pull start and there's a video that shows u how to do it its real easy.
Posted on Feb 28, 2011
  • 242 Answers
SOURCE: does switch need to be on when charging a razor pocket rocket?
No. The switch should be off before connecting the charger.
You can download a manual from Razor here...
http://www.razor.com/customer-care/owners-manuals/
Posted on Jul 14, 2014
Does switch need to be on when charging a razor pocket rocket?
Jul 14, 2014 | Razor E100 Electric Scooter
How do you charge a razor pocket mini motorcycle
You use the supplied charger, or if you got it used without a charger, you can buy one here: Replacement Razor Pocket Rocket PR200 Scooter Battery Charger Adapter... After that, you plug the charger into the wall securely, and pull down on the round cover next to the motorcycles power button until it opens. Then plug the other end of the charger into the motorcycle.
Jun 21, 2014 | Electric Razor Pocket Rocket Ride-on...
Razor pr200 pocket rocket. the tire is moving when i lift it up but when i sit on it it wont move
#1 check your power voltage on your batteries #2 you need to check the power to the electric motor - #3 possibly replace the control module - #4 possibly replace the throttle
Sep 06, 2013 | Electric Razor Pocket Rocket Ride-on...
I found a pocket rocket in a junk pile. All the plastic is gone but the rest is there. When I turn on the on-off switch it lights up and so does the light on the throttle but the bike does not run. What...
check the batterys with a multimeter and make sure that they are showing the correct voltage, also visually inspect the batteries for any bulging, and if you can shake the batteries, if they sound like there is sand in them then they are dried up, and you'll need new ones
Jun 06, 2012 | Electric Razor Pocket Rocket Ride-on...
I got a razor pocket rocket and my back wheel blew up. i have the replacement but i dont know how to do it pls help
Hope that helps!
Oct 10, 2009 | Electric Razor Pocket Rocket Ride-on...
Cycling Logo
576 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
