SOURCE: Yamaha ef1000 will only idle and produce 12 vac
Hi, I have the same generator and I pull the load and it is fine. The engine RPM is controlled by the
governor. The voltage will not come up until the RPM is at full. First see what the RPM problem is and then check the voltage. Open the cover and look to see if the carb linkage is hooked up , if it is you mite have carb problem and address that first. Hope that helps.
SOURCE: coleman 5000 generator will not idle up under load
Hi
You have to find the governor linkage.There is a spring adjusting by a screw to increese speed to get more power.Try to locate it.
best regards savumihai71
SOURCE: honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
SOURCE: I have a Honda 7000 EM inverter generator. When it
ARE SURE ITS THE OVERLOAD LIGHT AND NOT THE NOIL ALERT? IF ITS THE OIL ALERT ITS CAUSE YOUR LOW ON OIL OR THE SENSOR INSIDE THE GENERATER IS BAD?
SOURCE: kipor kde6700 starts but doesn't produce
check your owner manuel for how to excite the gen set. check breakers and see if this one has a fuss.
The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
