Computers & Internet Logo
A
Andy Sanders Posted on Jan 16, 2017
Planar monitor model #s19010 no cords how do I find the right cords and how do I set it up.
1 Related Answer
Buddy Mcsparrin
  • 1684 Answers
  • Posted on Feb 12, 2012
SOURCE: what kind of power adapter do I need for Planar lcd monitor model s1901d
They are available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=48
1helpful
I've got a Planar PL2010M monitor that is brain-dead-
1. Try a different DVI cable. 2. Check the monitor's settings and make sure it is set to the correct resolution. 3. Try a different computer or laptop to see if the issue is with the computer or the monitor. 4. Try a different DVI port on the computer. 5. Try a different monitor. 6. Check the video card settings and make sure it is set to the correct resolution. 7. Try a different video card
2answers
Dealing with a Planar PL1700-BK computer monitor. When power is supplied, the "no signal" box flashes, then the screen goes black. When hooked to laptop, screen shows desktop, then goes black.
Planar PL LCD Monitor Fix - MarsBox.com
marsbox.com > Blog > Howtos
Nov 3, 2008 - Planar PL LCD monitor has flashing power led with no image. ... You will know it worked if the monitor diplays "No Signal" message when ...
What is the method to reset the Planar 1910m monitor?
superuser.com/.../what-is-the-method-to-reset-the-planar-1910m-monitor
Apr 6, 2010 - My monitor (a Planar, apparently model number PL1910M) is not working. (It is flashing a green / orange sequence which I believe to be an error code. The sequence, in ... I wasn't even seeing a "no signal" message and I couldn't turn it off using the power button. ... Computer resets when put under load.
ViewSonic VX922 monitor - black screen - green power light flashes ...
www.tomshardware.com > Forum > Displays
Tom's Hardware Guide
Feb 1, 2008 - 50 posts - ‎27 authors
Repair ViewSonic VX924 LCD Monitor Blinking Green power Button ... cant switch back & forth to desktop out of some games without the monitor going .... Nothing else on the board looks bad, the power supply board is dark brown ... to this madness we are unfortunantly dealing with daily with our monitors.Missing: planar ‎pl1700
Can I use just the upstream hookup to connect an external monitor to my laptop? Also need to replace power cord. was not included Not the output needed Pwr rating says 12v dc 5.5a. That's all.
I use either VGA or HDMI connectors to connect to an external monitor.
I'm not sure what you're asking on the "power cord". Are you asking about the charging "brick" and such? Or?
Lock out my monitor px2710mw
Here is the user's guide for your monitor:
(from Planar's website)
http://www.planar.com/media/222919/mn-planar-px2710mw.pdf
Keeps saying "no signal -
I'm not sure what you are plugging this into, or through what type of connection; but if it is plugged into VGA make sure none of the pins are bent on either side of the cord, also make sure it is set to pick up the signal from the right input. If you need anymore assistance with this please let me know.
2answers
Resolution problem
A Chip on the monitor circut board must be reflashed. You need to send back to Planar, do an rma. They were very responive to me, sent me a replacement.
1helpful
3answers
Replacement External Power Supply
So the old power supply doesn't have the output voltage, current and polarity noted on the label? What a ripoff! *grin* Did you look on the case near where it plugs into the monitor? Sometimes that will tell you the voltasge and polarity. Poliarity? Get that one wrong and the monitor could be cooked instantly! But it's usually positive. I found a completed eBay listing that had this info: "the power supply which the seller used to power up this Planar Flat Panel is inventoried as follows: ViewSonic 12V Power Adaptor Model # SYS1126-5012" I looked that one up, and it's listed as 12V at 4.17A. PC Hub has them for $28.62: http://www.pchub.com/uph/laptop/345-19804-2285/AC_Power_Adapter_5V-12V_Others_SYS1126-5012.html Good luck!
Top Planar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
