Computers & Internet Logo
Michael Eddie Posted on Jan 16, 2017
PLEASE I NEED CHARGER FOR SONY CLIE CSK 002 /U
1 Related Answer
teacozy
  • Posted on Apr 03, 2008
SOURCE: Sony Clie
I found there is an online tutorial which said to hold down the power button for a few seconds and the light comes back on.
Need charger dc 5.2v=800ma
A Usb charger will be OK, make sure it's rated at 800ma or more, not 500ma as many are.
Need help
contacting by mail is not allowed here sir.
are you asking for the phone software similar to pc suite of nokia??
A Sony Clie PEG-N610C has been in storage for years(it appears unused). Neither the AC charger or the cradle charger will make the charge indicater light respond. It is completely dead in all respects. Can...
Since the battery is within the unit it can leak or go BELOW the threshold level of the cell wherein the charger will not work to charge the unit. However if you can confirm the battery voltage to be below, use a multimeter to check, then before replacing use a JUMP START with an external limiter DC bench supply , you can use a series resisitor of about 47 ohms with a 6-9 VDC.
If the battery takes up voltage the see if the charger will respond and the set will power.
3helpful
Cannot find my instruction manual. can you charge the battery on the computer using the usb cable?
No, the battery cannot be charged using the USB cable. You need the supplied battery charger. If you've lost it, you'll have to buy a BC-CSK or BC-CSKA charger from Sony.
1helpful
My Sony Clie PEG-TG15C doesn't charge...the cradle light doesn't go on...
Are you referring to the T615C?
You probably need to replace the internal battery.
Try a hard reboot while it's plugged into the charger first.
3answers
My son gave me a Sony Clie PEG-TJ27. He did not have info on how to use, can you help?
hello go through this manual below attached
http://printer1.blogspot.com/2009/07/sony-clie-peg-tj37-user-manual.html
Sony Clie sj22
IN BIOS SCREEN SET ALL TO DEFAULTS, BEFORE TRING TO INSTALL RE-PARTION DRIVERS
3answers
User Manual / operating instructions Sony Clie PEG-T425
Please repost your model number for your sony clie GPS. That might help. Sony Clie... doesn't cut it. Sorry.
Mike
Dec 24, 2007 • GPS
Clie T615 not reading memory stick
Either the stick is defective or the wrong format.
Top Sony Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
