Question about Rotel Audio Players & Recorders
Where within 10 miles of this zip 46761 can I purchase IF components resistors and other similar items to make repairs to my equipment
Repairing a Rotel RX-503 stereo I have no left side audio and there ae discolored component
SOURCE:
  • 979 Answers
SOURCE: "OVERLOAD" APPEARS
Have a service shop check out your protection IC and related network...accordianman
Posted on Oct 25, 2007
Duncan
  • 219 Answers
SOURCE: Blown car amp repair (Lanzar Opti 150 stereo bridgeable car amp)
Make sure your speaker load is correct before you blow your amp again after repairing it. I suspect that is why it keeps on blowing.
Posted on Jan 18, 2008
  • 4234 Answers
SOURCE: Rotel RX802 amp
I don't have a lot to go on here, but the amp should be repairable without too much expense. What specifically are the symptoms? Is it just that one channel is out or is that channel weak or distorted? I assume that you have checked for speaker fuses. Update this with a few more details, and I should be able to give you specifics.
Dan
Posted on Apr 03, 2008
oldnovii
  • 667 Answers
SOURCE: TV ranking
Hi. You could look up reviews. I personally usually never offer advice on choices, because what I like, may not be what you like..its a matter of personal preference. But in this particular case, I'd go for Panasonic. Why? Better features, better service, easier availability of parts, and better resolution.Plus some nice features. If this answers your question, PLEASE don't forget to rate as fixed. I'd really appreciate it. Enjoy your new tube!!!
Jeff
Posted on May 17, 2008
  • 4234 Answers
SOURCE: MHC-RV5
The repair manual can be purchased from Sony. What is the specific problem. Perhaps a manual is not needed.
Dan
Posted on May 20, 2008
The defrost blower stopped working?
Likely just a blown fuse, or a wire come loose.
Feb 22, 2015 | 2003 Kia Sedona
Behringer EUROPOWER PMP1280S smokes
If you mean that smoke is coming from the equipment, it's time to unplug it and get it serviced. This typically means that a component has failed - it can usually be identified because it will be physically deformed. You might see a crack in an IC, a burned resistor, or something similar. Often, though not always, the component that failed may not be the only defective component on the board - for example, a voltage regulator may fail, but it might be due to a faulty capacitor, or some other short-circuit on the board. It's best to refer the repair to someone who is skilled in troubleshooting.
Mar 08, 2014 | Behringer EUROPOWER PMP1280S Powered Mixer...
Recently blew a head gasket on my 2002 Elantra which I bought in Oct. 2001. Am I still covered for repairs?
10-YEAR/100,000-MILE POWERTRAIN PROTECTION Covers repair or replacement of powertrain components (i.e., selected engine and transmission/transaxle components), originally manufactured or installed by Hyundai that are defective in material or factory workmanship, under normal use and maintenance. Coverage applies to original owner only, effective with 2004 model year and newer model year vehicles. On 1999-2003 model years, coverage applies to original owner and immediate family members (i.e., wife, husband, daughter, son, stepdaughter, stepson).
Second and/or subsequent owners have powertrain components coverage under the 5-Year/60,000-Mile New Vehicle Limited Warranty. Excludes coverage for vehicles in commercial use (e.g. taxi, route delivery, delivery service, rental, etc.).
5-YEAR/60,000-MILE NEW VEHICLE LIMITED WARRANTY Covers repair or replacement of any component manufactured or originally installed by Hyundai that is defective in material or factory workmanship, under normal use and maintenance.
The following components are covered for time and mileage limits indicated:
• Radio and audio systems (i.e., radio, compact disc player, DVD player, navigation system, and Bluetooth®): 3 years/36,000 miles
• Paint: 3 years/36,000 miles
• Battery: 3 years/unlimited miles (100% covered 2 years/unlimited miles; after 2 years and within 3 years, 25% cost of battery and 100% labor cost covered)
• Air conditioner refrigerant charge: 1 year/unlimited miles
• Adjustments: 1 year/12,000 miles
• Wear items: 1 year/12,000 miles (e.g., belts, brake pads and linings, clutch linings, filters, wiper blades, bulbs, fuses)
Jun 21, 2011 | Hyundai Elantra Cars & Trucks
What is covered in the 100,000 mile/ 10 year warrenty for my 2004 optima
Mar 04, 2011 | 2004 Kia Optima
ABS light stays on; brakes lock up when brakes applied; I live in Pueblo, Co... where can I get a diagnostic and repair if needed. Thank you for your assistance.
FIND THE NEAREST SERVICE OR PART CENTER. To find the nearest Daewoo dealers within the USA, please enter Zip Code and/or State and type how many miles for ...
www.daewoous.com/Locator.aspx - Cached - Similar
Oct 15, 2009 | 2000 Daewoo Leganza
53UWX10B Convergence Problem
Had the same problem with so I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step pics of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. Try them
Louis
Jun 19, 2009 | Zenith R49W36 49" Rear Projection HDTV
I have a Marshall G100RCD guitar amp which keeps blowing fuses. Inspection of the circuit board appears to show to points that are burnt
You have a shorted output channel. You probably see burnt resistors and very heat stressed areas of the board. That is a sign of the outputs being shorted. Unless you have experience in repaired amplifiers you will not be able to repair this yourself. If you change the burnt resistors, they will most likely burn up again. The output transistors for one of the channels are also shorted. They must be replaced along with every other bad component. If you miss just one of the bad components you will most likely burn up all the good parts you just put in. Resistors must be checked to make sure they are within the rated tolerance, capacitors must be checked for being shorted or being dry, diodes must be checked for being open or shorted, output transistors and driver transistors must be checked for being open or shorted, and the list goes on. It is a very difficult job for anybody not experienced in repairing electronics.
Take it to a reapir center that will work on those type of amplifiers, not all repair centers will.
I am very sorry to give you such bad news, but it is the problem you are having.
If you need any additonal help feel free to ask, if you decide you are going to try and fix it yourself I can tell you what to look for and how to check them, but without the proper equipment you will not be able to do this.
If you found this information helpful a rating of "FixYa" would be appreciated. The "FixYa" ratings is not just for helping you fix your equipment yourself, it is also for helping you decide if you can even fix it yourself or not.
Thanks, and I hope you find a good repair center.
Dave
Jun 28, 2008 | Audio Players & Recorders
Samsung D840 screen problem
Sure everything can be fixed. it,s a matter of whether the repair is viable or practical for you. ( Expense Wise )
Your problem lies within 3 Areas.
1:) The Screen Inverter Board Is Faulty. This acts as a starter similar to in a florescant lighting tube.
2:) the screen itself has faults, relating to the cfl ( tube ) Or the matrix panel itself. ( TFT Monitor Panel )
3:) A Motherboard Power Fault. ( Or loose Connection )
Cheapest option First. Replace the inverter Board ( Located within the monitors Screen Panel )
secondly would to purchase a TFT Panel ( L.C.D Screen )
Finally is the Motherboard repair.
** Please note:- Any repairs on electrical equipment should only ever be carried out, by a person of competant and or extensive electronical Knowledge**
Mike @ compurepair.
Apr 27, 2008 | ASUS Z83V Notebook
Magic focus --blue and yellow sag in the upper left area of the screen
Hi, convergence circuit has failed, convergence IC`s and any burnt resistors will have to be changed, this is NOT an easy repair if your not very proficient at soldering and un-soldering components, you will also need a good (accurate) volt meter as the resistor(s) will have to be removed and checked for value and the values are critical to the circuit, ie: 3.3 Ohms must read within 1%, if you have the tools & soldering experience get back to me and I`ll tell you where to go to get the parts, if not you need to get the set to a tv shop, BMW Rider
Jan 13, 2008 | Hitachi 53FDX20B 53" Rear Projection...
32 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
