Mark,
1st we need to determine if there is a fault in the alternator. Run the below test to check. (Just ignore the brushes readings as yours do not have brushes.)
ONLY DO THIS NEXT STEP IF YOU ARE SURE THE TESTS HAVE TOLD YOU THAT THE ALTERNATOR IS FINE. If all tests ok then you can reduce the engine speed to bring down the voltage. You can do this by adjusting the screw at the top of the carb. Do so slowly and use the voltmeter to check the output. How to test your Electricity Generator AVR Brushes and Alternator on...
The RPM lowered should lower voltage, try it by hand, plug in the volt meter and push the throttle on top of carb with your finger ,should not take much .
