I have a Echo 230 SRM and I want to replace the exisiting trimmer head and replace it with a U-Turn trimmer head. The problem is that I can't get off the current trimmer head. If there is anyone that can be of assistance I would appreciate it.
Don't know for sure, but I found manual on amazon, Amazon com echo srm manual so take a look if you want. have a nice day
On the head there is a u shape slot on the side. turn it until you can slide a small screw driver in it to lock the head. then loosen the nut on the bottom i do believe it is a left-handed
Remove the top off the string housing and remove the nut in the center.
Replace the top, as if you have finished loading string, Lock it in place as you normally do and the turn the entire housing pulling up at the same time. Spring and the white mechanism will pop out and then all you have to do is lift the string housing base off the trimmer head. Note it will take you a few tries but once it comes off you will see how easy it is to remove. I was amazed. Got my info from a sales person at Home Depot.
