SOURCE: cant find the right flapper for jacuzzi brand
Lowes used to carry some of the oversized flappers. If they dont anymore start calling the plumbing supply houses in your area. Hope this helps.
SOURCE: How do you replace the flapper for a 1.6 gallon,
http://www.ccowhirlpool.com/web-pdfs/Jacuzzi_Whirlpool_Bath/Toiletry.pdf
The top link has diagrams of internal working's of different types of Jacuzzi toilets. Most of them have a tab's on the over flow tube that the flapper will fit on. Shut water off and flush tank to get most of the water out and take a look on how the old one is connected. And replace with a new one. Check out the chain or plastic string which connect's flapper to handle to get proper adjustment for flushing toilet.
http://www.google.com/search?q=replacing+flapper&hl=en&sa=G&rlz=1T4GZAZ_enUS363US364&prmd=v&source=univ&tbs=vid:1&tbo=u&ei=S3AcTNrBGYL6lwfN1NmnDg&oi=video_result_group&ct=title&resnum=4&ved=0CCoQqwQwAw
This link will instruct you with video on how to replacing the flapper.
SOURCE: need parts for a 30 year old jacuzzi toilet
Depending on what the innards look like, you can spend $15 at a home center like Home Depot for a toilet replacement parts kit. They're easy to install (about 30 minutes) and fix most common toilet issues.
If this won't work you might need to contact a plumbing supply company in your area. You'd be surprised what they have in inventory....
SOURCE: Need to order a replacement toilet seat for Model
I have problems with booths of my toilet seat.
When sitting down it move's & every think is tide .
My question is WHY ?????????????? It is also very unsafe, you feel like you will fall of the seat.
SOURCE: I need a gasket for the flapper of the jacuzzi
local wholesale plumbing supply house. most are listed in the phone book.
