Hello Lisa,
I love these cookers, they are beautiful.
FIRST OF ALL, REMOVE THE PLUG
Then pull the cooker out of its place and unscrew the backplate on the side where you think the problem is.
When it really is the ventilator, you will find then some very dark colored wires.
The reason for this is most often a bad contact.
When the wire is not burned to much, remove the burned connection, clean it and put it back again.
In case of a really bad burne wire, do not replace the wire, but use shrink hose
Just be sure that the connection is ok again.
Replacing Burned Wire Connection in Oven Mom in Music City
The second link is of a VW Samba, but illustrates what can happen. Then you can immagine that nothing will work anymore
TheSamba com Gallery burned wire
SOURCE: rangemaster leisure 110
Hi
Just to say we sorted the problem. Simply the bulb was out in the one oven. We replaced this and problem solved.
Carole
SOURCE: how to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
SOURCE: hello where will i find my serial number on the
Remove the drawer and the sticker will usually be on the right hand side of where the drawer goes in.
SOURCE: Both ovens only light to pilot light, wont go
Faulty FFD's ( flame failure devices) once the flame is established it allows the full flow of gas to the burner... must be a gas-safe engineer to replace part..
SOURCE: I have a leisure rangemaster 110 dual fuel cooker.
at the back of the timer/clock there are 4 wires live and neutral to power the timer/clock and 2 others they may be red or orange. safely connect these other 2 together and you are good to go. if you need a new clock email me [email protected]
