Televison & Video Logo
t
theresa hutchins Posted on Jan 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The antenna port is broke off on my lg flat screen tv how do i fix it
Darran Hatten
Level 2:
  • Expert 236 Answers
  • Posted on Jan 14, 2017
Darran Hatten
Expert
Level 2:
Answers
236
Questions
0
Helped
129309
Points
792
It's possible to resolder the port back on but the tv will have to be pulled down to gain access to the tuner and tuner cover will need to be removed to resolder the signal wire where it's broken off the tuner board. In some cases the tuner needs to be desoldered and removed to get access to the tuner board. If your soldering skills are not great an alternative solution would be to use an external set top box. This can be a pest because you then need a second remote to change channels.
1helpful
I have a LG smart Tv the picture is very good but the picture is very blue ?
What is the model number of your TV?
What are the devices connected to every port of your TV?
Disk; Cable; Antenna; DVD; HDR; Ethernet; USB; Soundbar ?
is the picture better with other INPUT sources ?
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
I have a Seiko 50 inch flat screen tv were on the tv do I hook up a digital antenna
All terrestrial broadcast inputs go to the co ax input port, the TV will auto sort between analogue and digital inputs.
Ant -cable port Broke off the back of TV Hisense LCD TV Model#. Ltdn42v77us
Contact any service technician. In most cases, the turner might have to be replaced, as the antenna socket is the part of the tuner case. Gopakumar Gopalan Google
2answers
My screen broke moving on my sony flat screen. Tv
I would try contacting<a href="http://www.tvvideorepairil.com">flat screen tv repair in Chicago, IL</a> because that's where I went when mine broke.
2helpful
Antenna in port connection broke off the tv
You can purchase the whole main pcb for the tv, but this would be costly with arts and abor. You could order just the part you broke called the Tuner but, you would need to know how to solder to take off the old and put on the new one which is time consuming. The cheapest and easiest way is to if you do not have cable or sattelite and just have an over the air antenna, get you a converter bx with the composite outputs "red,yellow,white" and connect that to your tv. Thats the cheapest and simplest work-around fix. Good luck!
2helpful
2answers
I have many lins in my LG LCD screen , how can i fix this probleme please .
most likely this is not a problem with you TV it is a problem with the Antenna or the cable.
you need to check all the connections from the cable box or from your Antenna not to be loose.
also- contact your cable company and have they look into the quality of the transmitting you are getting.
I have an LG47LG70 tv which has recently started flashing the screen on and off when hooked up to the local antenna. It works fine when hooked up to the Dish Network cable. I have replaced the antenna...
Tries hook up to a roof antenna or a better antenna like a digital antenna.Than rescan ur tv again,for those DTV free air channels again.Ur tv now,should get all those DTV free air channels.
My wii remote just broke the screen. is it fixable or do I HAVE TO BUY A NEW TV
Call LG trade in the broken LCD screen tv.Get some discount for the purcharse of a new tv.Not worth it to replaced the LCD broken screen,because they're limmtted produce,replacing the LCD screen and labors will exceed or same as a new tv.
1helpful
Why does my digital TV image fall apart into pixels and the sound breaks up - when I switch the digital box to TV antenna, the reception is ok, just not so sharp as with digital conversion. Is it a problem...
Tries directly to a good antena,like outside antena.or a digital antena,no need for any box,new LCD Flat screen tv have an converter in side,no need the box help only old CRT tv have no converter board in side.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
