Cameras Logo
S
Shaukat Sheikh Posted on Jan 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nokia 6x fell and now its camera and flash light are not working, i need advice
Tony Parsons
Level 3:
  • Nokia Master 6,405 Answers
  • Posted on Jan 14, 2017
Tony Parsons
Nokia Master
Level 3:
Answers
6405
Questions
Helped
1650088
Points
20272
Take it to a reputable repair facility.
1 Related Answer
Anonymous
  • 177 Answers
  • Posted on Jul 27, 2010
SOURCE: HAVE A FINEPIX 6900ZOOM 6X CAMERA ,NEED A OWNERS MANUAL&MEMORY
Here are the Manuals: http://www.fujifilm.com/support/digital_cameras/manuals/#s
I need my GE digital camers (E1680W) repaired
I suggest visit some photo service looking the yellow pages using your ZIP code.
3helpful
My nokia 6300 phones back light is not working correctly. The keypad light comes on and later the screen light which goes off when you press the key pad. please advice
does your phone accidentally fell on a hard surface? if that is so, then, the board itself is loose thats why you have problems with the backlights. go to your nokia center and have it fixed. its just a minor repair.
1helpful
My nokia 6300 phones back light is not working correctly. The keypad light comes on and later the screen light which goes off when you press the key pad. pleas advice.
My daughters Nikon D40 accidentally fell on the floor and now the flash has quit working. It still takes pictures fine it just won't flash. Is this something that will have to be repaired by a camera shop...
Unless you are a camera guru my strongest advice is to have a professional take it apart to look at it. You could have very well have only broken the flash bulb or caused a connection to lose its seat on the circuit.
Shake the camera gently and listen to the flash for the "jingle" of broken glass. If you hear nothing, and are comfortable with taking the camera apart, unscrew the flash housing and check to see that the wires are all still well connected.
Cheers!
Manual light & exposure settings
if you are using flash lights on the art work, please follow the following steps
  1. turn off your flash in cam since it bypasses the external flash and makes the picture look different.
  2. turn your light settings to either automatic or "flash light or arc light".but do not set them to incandescent light!!!
  3. turn your macro to on status if you are going to take a close up shots, but please note that close up shots work great in natural sunlight than at flash lights...
A light on the back of my nokia intrigue won't turn off
you have to open your phone, if you didn't done this before i advice you to go to a repair shop, you'll have to remove flash LED
Aug 14, 2009 • Cell Phones
3helpful
Turning the flash off
Set the mode dial to Camera (normal) then by pressing the Up button on the control pad, you may switch between the different flash settings. The settings are:
  • Forced flash (lightning bolt)
  • Slow synchro (bolt plus SL) - this is forces the flash to strobe out of sync so a dark background can be lit up.
  • No flash (no bolt)
Please rate FixYa! ThankYa!
Top Nokia Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Nokia Camera Expert? Answer questions, earn points and help others
