Nikon DSLR D90   Digital Camera Logo
B
Buonamassa Gualtiero Posted on Jan 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My nikon d 90 does not focus in A mode with 18-135 lens always searching for focus point.Is in the menu to change some things.
Tony Parsons
Level 3:
  • Nikon Master 6,405 Answers
  • Posted on Mar 15, 2017
Tony Parsons
Nikon Master
Level 3:
Answers
6405
Questions
Helped
1650158
Points
20272
This can happen in low-light conditions - how does it behave in daylight out of doors ?
Melissa Timberlake
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
Melissa Timberlake
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
3268
Points
31
Is it just in A mode?
5 Related Answers
d4444n
  • Posted on Jan 23, 2008
SOURCE: Trouble auto focusing
If it's any consolation, I have the same setup and the same problem. I'm now at the point where I'm probably going to have to return the lens as faulty, but there are a few things it could be on yours which you might want to check.
Have you got the D200 set to auto-focus? The selector (on the front of the camera, on the lower left) should be in the S position (as opposed to C or M).
Have you got the lens set to auto-focus? It should be in the M/A position, rather than M.
Have you tried cleaning the contacts? Pop the lens off and give the contacts a clean with the appropriate equipment. Dust on the contacts could be causing a problem.
Failing that, have you tried turning the camera on and off a few times?
I've obviously tried all the above on mine, and now suspect I've got a faulty lens that needs fixing ... which really sucks! Good luck with it, let me know if you get it working.
Dan
Anonymous
  • 5 Answers
  • Posted on Oct 20, 2008
SOURCE: nikon d40 lens
The Lens focusing motor is broken and it is replaceable
ibeinsane
  • 3 Answers
  • Posted on May 29, 2009
SOURCE: Nikon DX 55-200mm lens
Hi, I had this problem and found that the level inside the camera for the exposure shutter was bent inwards. This was preventing the lens from adjusting the exposure and also from autofocusing. To fix I just bent it back outwards
Anonymous
  • 123 Answers
  • Posted on Jun 13, 2009
SOURCE: nikon 18-200 mm vr lens not auto focusing on my nikon d200
lets start with the basics, try hard reseting it and try again, if that doesnt work then
try upgrading your firmware (if possible on your camera) and if that doesnt work then it may be the lens, but dont forget to spend a few hours trying to find a option for it in the meny
Anonymous
  • 63 Answers
  • Posted on Apr 16, 2010
SOURCE: Nikon D50 with Nikon DX 18-55 lens will not focus
Sorry to hear about your lens. If you are able to autofocus and take pictures with any other lens, then it means that your problem lies with the kit lens. If you can take picture in manual mode, but not in autofocus mode, then the AF motor in the lens in not functioning. I had the same thing happen to my 50mm 1.4 lens.
Depending on your location, there are Nikon repair centers in Melville, NY and Torrance, CA.
Hope this helps,
Andrew
Nikon D50 will not autofocus, the menue item 02 Autofocus is no highlighed and I can not set it
You should check two switches.
First, on your lens, be sure it's set to M/MA not M. That puts the lens in auto focus mode.
On the camera there should be a switch that shows C/S/M. If switched to M, it's on manual focus. Change this to S for single auto focus or C for continuous auto focus.
Hope this helps,
Andrew
My Nikon 17-35 F2.8 zoom won't Auto focus or show F stop
The F/stop isn't supposed to change when you focus. Depending on the camera, you change the f/stop by either turning the aperture ring on the lens or turning a command dial on the camera body.
2answers
Focus On My Subject
Change your metering mode to spot metering. Focus on your subject with half-press of shutter button...hold that press while you re-compose the picture and press the rest of the way. See if you get better results.
1helpful
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
1helpful
Nikkor af-s 18-200 VR not focusing
Please check your focus settings in the camera menu. Play around with the focus point from Single to 11 points. Also, try Auto mode as a quick way to test if the focus is working
Nikon d40 wont autofocus
Your 28-90 AF-D lens can't autofocus with the D40, which requires AF-S lenses with a focus motor in the lens. Sigma lenses with "HSM" (HyperSonic Motor) in the name also have the focus motor.
1helpful
4answers
Nikon D80
EXPLANATION.
1. The problem with 18-135 lens is because it make from plastic. Main problem from plastic is it can be reshaped after a few usage. When the shape ran out, the contact point will be defective. When the contact point didnt really touched, the processor cant send signal to lens to do autofocus (the lens focus using the lens motor, not the body). When u set to manual focus, the body doesnt need to instruct the lens to focus.
2. You are focusing something that is to near than the focal point.
SOLUTION.
1.Try cleaning the contact point on the lens. Then mount it back until the F showing up (F= aperture). This solution depend on your luck too. if the gap between to contact is so far, then it might happen back. Usually when u need it badly. haha
2. try to get more distance from your subject. Just keep press the shutter until the camera focus.
CONCLUSION
1.But new lens with metal mounting. It will last and durable.
2.Buy macro lens to close up. normal lens wont focus at short focal point!!~
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
