SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
SOURCE: problem with upright freezer not freezing
It sounds like the unit is low on freon or the compressor is going bad. You have several other components that could be affecting this as well. Make sure the coils are free from dust and clean underneath. This is a bit premature for you to have problems now, especially since it is a Sears product.
SOURCE: woods upright freezer
I would look at the defrost control [sometimes they are defrost clocks]Maybe that the freezer is not defrosting.
SOURCE: water in bottom of freezer
the drain needs to be check for any kind of blockage. if the drain is blocked or frozen over this needs to be cleared
SOURCE: We bought a Woods all fridge and upright freezer pair
Do you know what parts are needed? Some are available and some are not.
Jeff-it is NOT running
Woods is no longer in business. Some of their upright freezers were recalled but I was not original owner.
Figured that's what you meant, Jeff.
