SOURCE: coffee comes out cold
Hi this is tech crazy
The problem in your coffee maker is due to the above said reason:
To keep the heating element from overheating, there are also components such as sensors and fuses. In coffee makers, sensors detect if the coil is getting too hot and cut off the current. Then, when it cools down, they turn the current back on. By cycling on and off like this, they keep the coil at an even temperature. Fuses simply cut the power if they sense too high a temperature. They're there for safety reasons, in the event that the main sensor fails.
From my experience i personally feel that replacing of theses things would cost almost to a new coffee maker machine.
So,its left to you sir/madam to decide upon the new coffee maker machine.
Kindly rate me on the above said soltion
SOURCE: My Delphi XM2GO MyFi has
IF you take it out of the home dock and run it on batteries, I'll bet you it works again. The newer home docks TURN OFF the FM transmitter. Try a car dock, or try it with just the power plug plugged into the bottom of the MyFi, without the home dock and see if you can now get the FM transmitter to work. Let me know. Thanks and good luck.
