SOURCE: ou je peux trouver le driver pour mon cell
my friend is informatien and he solved this for me i don t know how
thx a lot
SOURCE: disque cod?
To have answers in these types of groups it is best to translate in to English.
The question in English:
Hello, I have a problem with a laptop which called for a password bios. Well, I removed the battery for a moment and that is installed. I launched the boot on the disc cd then it did the restart, it asks me a password hard disk. I then passes through several means even SKY_FOX I tried but nothing.C 'is a brand Fujitsu Siemens Lifebook and I do even more started on the system' exploitation. I really need help, if you could do something without needing expensive experts. Thank you.
__
Have you contacted the former owner to get the password?
If the hard disk is pass-word protected and you do not have the password, the fix would be to un-install the partition, and re-make it. Then do the full re-installation of the operating system, and the re-registration for ownership.
In some cases where the hard disk is password locked, there may be no possible way to be allowed to undo and re-make the partition to do a full re-install. If this is the case, changing the hard disk will fix it. The old hard disk would be scrapped unless you can have its password.
BIOS Level Password Procedure:
With some models of computers, you can remove the BIOS battery and wait until the BIOS setup is depleted. Then you should then be able to have access to re-set up the BIOS. You will have the choice to put in a new password or simply not to.
If the computer hardware is pass-worded at the BIOS level and it does not deplete with the battery removal, you will have to send the computer back to the manufacture to have the computer un-locked. You will have to pay the shipping and the service fee. When sending the computer back to the manufacture for the unlock, you will be asked for proof of ownership of the computer with proof of identification. With most computer companies, a copy of the purchase invoice, and a copy of your driver's permit or citizenship card should be acceptable.
________________________________
Google Translated, Answer in French:
Avez-vous contacté l'ancien propriétaire pour obtenir le mot de passe?
Si le disque dur est mot de passe protégé et vous n'avez pas le mot de passe, le correctif serait d'installer un-la partition, et re-faire. Ensuite, faites le plein de nouveau l'installation du système d'exploitation, et le ré-enregistrement de la propriété.
Dans certains cas où le disque dur mot de passe est verrouillé, mai il ne peut être moyen d'être autorisé à annuler et re-faites une partition de faire une re-installer. Si tel est le cas, changer le disque dur fixe. L'ancien disque dur serait supprimé à moins que vous ne peut avoir son mot de passe.
Mot de passe BIOS niveau procédure:
Avec certains modèles d'ordinateurs, vous pouvez supprimer le BIOS batterie et attendez jusqu'à ce que le BIOS est épuisé. Ensuite, vous devez alors être en mesure d'avoir accès à re-configurer le BIOS. Vous aurez le choix de mettre en un nouveau mot de passe ou tout simplement ne pas le faire.
Si le matériel est libellée au passage à niveau le BIOS et ne pas épuiser la batterie avec le déménagement, vous aurez à envoyer l'ordinateur à la fabrication d'avoir un ordinateur sans littoral. Vous devrez payer les frais de livraison et les frais de service. Lors de l'envoi de l'ordinateur à la fabrication pour la déverrouiller, il vous sera demandé une preuve de propriété de l'ordinateur avec la preuve d'identification. Avec la plupart des sociétés informatiques, une copie de la facture d'achat, et une copie de votre permis de conduire ou carte de citoyenneté devrait être acceptable.
Jerry G.
SOURCE: drivers pour le chip CS4180-CM pour win98 fe carte m?re kzm-6120
Vous pouvez trouver les drivers pour:
Cirrus oficial site
Je suppose que vous avez utilisé les drivers du CS4281
Alternative download
SOURCE: how to unlock my sony
Accidentally
locking your Vaio keyboard can cause typed letters and/or numbers to appear on
the screen very slowly, or not at all. The locking function can occur if a user
holds down the shift key for more than eight seconds. This feature can be
unlocked through the computer's Microsoft Accessibility Options. 1. Click "Start," "Control
Panel," "Ease of Access" and "Ease of Access Center." 2. Click "Make the keyboard easier to
use." A new window will appear. 3. Remove the check-marks next to "Turn on
Mouse Keys," "Turn on "Stick Keys" and "Turn on Filter
Keys." This unlocks your keyboard. 4. Click "Apply" to save changes, then
"OK" to exit the window. if you think i misunderstands your problem or you have any other problem you can post again
