Coffee Makers & Espresso Machines Logo
s
sue pierce Posted on Jan 12, 2017
What is a phone number to reach the bunn coffee maker company
2answers
My bunn nhb makes a continuous "boiling" sound even after coffee has brewed.
Check with Bunn and see if there has been a recall. I did in Canada and they sent me a new machine complete with some Tim Horton's coffee! http://www.bunn.com/
Good Luck!
3answers
Leak from hot water faucet
Replace the water faucet. Contact the company the unit was sold or installed by. they should have the part in stock.
My Bunn VPR makes a high pitched sound while coffee is brewing.
Your unit needs service. Contact the company that sold or installed the unit.
Boiling water out of tank
Sounds like a thermostat problem.
Best bet is to have a service tech check it out.
Contact the company it was purchased from.
Also could check the local phone book for a service company near you.
1helpful
Our coffee maker is leaking. bunn b10. i see they make a kit with silicon washers but how do i get to them to replace?
Hello, goto www.bunn.com for replacement parts. The most likely reason for the leak is the gasket between the pour tray and the tank. If you cant get parts from bunn there is a company call holiday house in cali that will sell you the parts you need. Mike
When pouring coffee it drips, also doesn't keep coffee hot
Hi - Any time I've had an issue with my Bunn BT10-B, I go to the website, www.bunn.com , and go to their Customer Service area. They have been extremely helpful and informative.
2answers
Bunn Coffee maker leaking out of the bottom of the coffee maker when the coffee maker is not making coffee.
that needs to go back to bunn for a replacement tank, they will likely only charge you for return shipping
Hi: My Bunn coffee maker started leaking. Can this be fixed. he Model is NHB and date code is 145105. My address is: Tom Allen 3800 South Garrison Chapel Road Bloomington, Indiana 47403 PH...
Tom, your machine is out of warranty but we can offer a replacement brewer for $68.43. In order to do this, please send in a check or money order with your brewer to the following address:
Bunn Corp
900 E Townline Rd
Creston, IA 50801
Please include a note with the machine with your. name, address, and phone number.
1helpful
2answers
Using fine grind coffee in my Bunn Coffee maker is causing overflow grounds into my decanter. My Bunn manual says that I can receive a "Flow restrictor sprayhead" free of charge. How do I go...
Phone Bunn Directly, and ask for their warranty department. In canada, you can call 1-800-263-2256. In other countries, go to www.bunn.com for the phone number closest to you.
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
