Looking for start and run capacitors for a Dayton 9NCG4 with frame 56, they should be just like the ones on the new identical motors, need the numbers so I can place an order
On a single phase universal motor with a start and a run capacitor, that is handy.
The start capacitor is fully automatic as there is an internal centrifugal contact that breaks the contact when the motor reaches near running speed.
The run capacitor puts one of the motor windings out of phase with the other and determines the direction. Placing the run capacitor on the neutral will make the motor go the other way than on the live.
Waterway Executive 56 Spa Pump, 5 HP, 230V
Waterway Executive 56 Frame spa pump wet end
assembled to a 56 frame, 5hp, 2-speed 230V spa motor
This Spa pump has a 2-1/2 inch intake and a 2 inch discharge for plumbing
(but measures 3-1/2 inch and 3 inch- see bottom of this page)Manufacturer Part No. 3722021-13 Other Part No. PF-50-2N22C Features:
Executive spa pump wet end designed specifically for 56-frame spa motors
Two double shielded ball bearings with moisture resistant grease for quieter operation and longer life
Two speed spa motors have four sets of insulated windings for increased efficiency
56 frame spa motor for added strength, cooler operating temperature and longer motor life
Large 2-1/2 inch intake for improved flow performance and reduced noise
Large 6-1/2" diameter wet end for higher head pressure
Split capacitor, (start and run) for less energy consumption
Thermally protected to extend life expectancy of hot tub motor
Highly versatile wet end can be rotated every 90 degrees
Viton seals
Three year manufacture's warranty on spa motor and spa pump wet end
The 2 brown wires to the cap in first legend is how they are wired electrically,inside that motor the run winding is common to that brown one they cappped off in the 2nd option, but the powers still going to Run.ommon and run get the juice either way, its just another way to do it, but electrically as to sides of power and where they go is no different, just different way to do it.you can run power in on the Run terminal on the run cap, the run winding and run cap and start cap if equipped are Run to Run to Run.So the hot leg for the run winding also goes to run on the caps, run to run to run.,run winding to run cap to run on start cap.
