Question about Rockford Fosgate Car Audio & Video
Bridging two12" subs and one 15" sub to my Rockford fosgate T 1500bd amp
    Genius:
  • 1,066 Answers
Assuming all 3 subs are 3-4 ohms, running all 3 in parallel (the 3 positive leads all attach to the amp positive terminal, and all 3 speaker negative leads connect to the amp negative terminal) will bring you at or above 1 ohm, which the amp is capable of handling. With 1500 watts, you will want to use 8 gague power leads for the amp, 12 gague speaker cables, and an inline 120 amp fuse between the amp and the battery, within 1 foot of the battery.
Posted on Jan 11, 2017
SOURCE:
How do I hook up my inside speakers and sub's to
if setup 4 channel amp with low pass filter for the sub channel and other 2 channels for speakers with no filter, some amp you can use amp as 3 way if one or two subs, bridging output will give you more power for the sub. be aware that bridging 2x4ohm subs will give you 2 ohms and potentially damage the amp.
Oct 21, 2014 | Car Audio & Video
How to bridge a 1 channel 1000 punch 55amp
You can not bridge a 1 channel amp. Bridging is when you combine the output of a bridgeable two channel amp into one channel, typically to power a sub woofer.
Feb 13, 2012 | Rockford Fosgate Car Audio & Video
How do I hook up one sub to my rockford fosgate p3001 amp
Hey i have looked over many rockford manuals,(i own a 300.1 my buddy owns a 325.1) and for there mono(.1) amps there hooked together on the inside so channel A+ and B + are cencted on the inside the amp. So you ither hook one 2ohm sub to channel A or you can hook 1 4ohm subs to channel A and 1 4ohm sub to channel B. There 2ohm stable so any lower will eventualy burn the amp out.
Jan 08, 2010 | Rockford Fosgate P3001 Car Audio Amplifier
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
I have a rockford fosgate punch 150 and it will power a small 5 1/4" speaker, but doesn't seem to push my 15" subwoofer. I am reading 4ohms across the sub so I'm assuming that it is fine and that there is...
amp is way too small to power a 15 inch sub. But you should get some sound out of it, not silence. You can use a 9 volt battery to test your sub, if the sub pops when the 9 volt is placed across it's terminals then it's ok. If it does not pop then your sub may be bad, or the coil may be frozen. (It can still read 4 ohms if frozen). If your amp powers smaller speakers fine, you know it's not the amp. If the sub tests ok, then verify your connecting it properly to the amp's correct bridging terminals.
Jun 12, 2009 | Rockford Fosgate Punch 150S Car Audio...
Sub Wiring
Hello jtkpay,
Rockford-Fosgate claims their latest V-power 1500bd is stable to 1 ohm, and I would think that your Oldschool would also be. The 2 wiring options for 3 subs with 2 ohm dvc would give you a 1.34 ohm load and a 3 ohm load. The 1.34 ohm option would mean more watts to the subs, but the amp will run hotter. The diagrams look like this:
Using just 2 of the Kickers, you can wire 3 different ways, with final impedances of 0.5 ohms, 2 ohms, or 8 ohms. You do not want the 0.5 ohm load. It's bad for the amp. You don't want the 8 ohm load. It doesn't allow the amp to produce as much power. So that leaves only the 2 ohm, with coils in series and subs in parallel. It looks like this:
Hope this helps. If it does, please rate as "FixYa".
Apr 27, 2009 | Rockford Fosgate Power 1500BD Car Audio...
Rockford Punch HE2 wiring question.
if your sub will handle it, bridging it will give you more power. The best thing to do is to find out how much power the amp puts out ( RMS ) and if it is in your power handling range bridge it. It sounds better and gives you a harder punch because of more power.
Feb 05, 2009 | Rockford Fosgate HE2 RFP4212 Car Subwoofer
Subs lock in place. Only direct current comes out of the speaker output
The amp has failed and will need to be repaired.
Let me know if you have any other questions.
Jul 18, 2008 | Rockford Fosgate Power 1500BD Car Audio...
Sub hook ups
There's a lot more factors involved than that.
  • Power capability of the subs
  • Type/size of the sub box
  • Allotted space in the vehicle for the sub box
  • Voice coil impedance of the subs versus the capability of the amp
  • Etc.
Jun 19, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
Trying to wire my amp to my subs
no thats not it you are lucky you havent burned it up like that. wire each speaker to its own source positive and negative, you loose power when you bridge an amp and use two speakers, its best to hook up without bridging you will get more volume that way.
Dec 18, 2007 | Infinity Reference 1211a Car Audio...
Car Audio & Video Logo
110 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Mike Duncan
Mike Duncan
Dalynn Turner
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
