Hi - You need to contact Quinny USA customer care team for assistance -
[email protected]
SOURCE: does quinny dreami bassinet fit 2005 buzz frame?
Yes, you can!
Basically, the design for the Quinny Dreami has not been changed since 2002. So any Quinny Dreami since 2002 will fit any Quinny stroller/pushchair since 2002.
With kind regards,
www.Babycare.nl
Erwin de Raad
SOURCE: Dreami - Black Bassinet: I've just bought a Quinny Freestyle and would like...
Yes you can. You need a set of adaptors( the same ones as for attaching a maxi cosi car seat) You remove the seat unit by unbuckling all straps and taking it off. Then you then need to remove the 2covers above the quinny logo on the sides of the pushchair frame. You do this by pressing the silver buttons to release them and then they should slide off. You then replace these with the adaptors for the carrycot. These slide into position until you hear a click. They are marked left and right. The carrycot is then placed onto these(again it will click on) parent facing. To remove the carrycot you then press on the silver buttons on the carrycot unit and lift off using the handle in the carrycot hood. HTH
SOURCE: I have a Quinny Dreami Bassinet - Gold...the
hi
i'm not sure you can fold the buzz with dreami still attached
here are upto date instructions for the dreami
http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%20Dreami%20UK.pdf
for the buzz
http://www.quinny.com/media/producthandleidingen/Quinny/2009%20Manual%20Buzz%203%20UK.pdf
after reading them i would say it has to be removed(I only had the pushchair)
SOURCE: i would like to get
Good Morning
If you're a UK customer you can order via your local retailer or direct with customer services on 01284 413 141 Mon-Fri 8.30-4.30. RRP £20, if you purchase direct the cost will be RRP plus £3.99 p+p.
If you're not a UK customer please visit www.quinny.com and select the country you're in, then select "Contact Us" to enquire about availability and costs.
