You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
SOURCE: stops and starts
Most home standby generators are setup to run once a week so as to keep the engine lubed up and the generator windings dry. So if yours is comming on once a week at about the same time and running for something like 15 minutes, that's what is going on.
On the other hand, if your generator is starting and the switch is transferring somewhat randomly, you could have a problem with the neutral connection in your system, the power could really be going out and coming back on, and/or the control board in your generator could be broken.
Regards,
Carl
SOURCE: No Power
AVR card is located right outside the stator...here is an image demistrating:
and the AVR looks something like this:
SOURCE: Hi, My Kipor 6700TA wont start. Battery died or fuel issue?
It sounds like your unit may not be charging the battery properly.
Try charging the battery and see if it responds properly. If it does, then check the charging circuit. This OFTEN involves a rectifier module which is usually about 1 inch square with four leads. OFTEN there is a fuse, sometimes within the generator housing (stupid place) which protects the low voltage winding.
Here is a hint: Most of these engines have a compression release on the top that one can press then crank up to speed and release. This takes much less effort on the battery. Some have a panel held by bolts. I put hinges on mine for easy access.
REMEMBER the battery is being drained WHILE the unit is running to hold the fuel solenoid open... so if charging isn't working the battery will die.
Test: You should see about 13.75 to 14 volts across the battery when properly being charged while running.
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
