Posted on Jan 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Minolta EP 3170 copier will not switch on
Been Standing 10 years, disconnected, under dust cover. Worked perfectly well before that, Checked wall socket. Checked plugtop fuse. Checked fron cover is closed. Turning on, nothing happens as if the copier is dead
  • Norman Weimar
    Norman Weimar Jan 14, 2017
    Talk about a legacy machine, check the power supply with a volt meter red wires is 24 volts green ground,white and black 117/120 wall voltage!!!
Norman Weimar
Level 3:
  • Minolta Master 7,035 Answers
  • Posted on Oct 21, 2022
Norman Weimar
Minolta Master
Level 3:
Answers
7035
Questions
Helped
1910612
Points
11959
Ensure the power plug is properly installed not lose. That is a serious legacy (Super Very Old) machine. Unplug machine and remove rear covers. Look for fuse or circuit breaker. loose connections. if notice nothing plug in and using a volt meter test for voltages on any red wires connection. Black and white wires are 120 VAC be care full green ground
5 Related Answers
Anonymous
  • 86 Answers
  • Posted on Mar 30, 2007
SOURCE: Dead Epson C84
STOP using the wall outlet to shut off the printer; ALL inkjet printers need to go through a certain shutdown routine which ONLY happens when you use the proper "OFF" button on the printer... You will have to find the user's manual for your printer, or download a new copy from the Epson website... DISCONNECT the printer from the computer, then follow the instructions from the user's manual on how to print a test page (usually requires holding down a certain button while turning the printer on). Again, do this AFTER you disconnect the printer from the computer; the printer is designed to run through a quick self-test under those conditions, and it will attempt to print a test page when it completes the self-test process. If the test page prints successfully, you can shut the printer down, then reconnect it to the computer, and reboot. Your problem should be solved, and you'll know what to do the next time this happens. It would be best if you move the printer to a single power source, one that will prevent you from shutting off the printer unless you use the proper shutdown procedure. Good luck; hope this solves your problem...
Anonymous
  • 4 Answers
  • Posted on Feb 26, 2008
SOURCE: WhOW TO REPLACE THE EXPOUSER LAMP IN MINOLTA COPIER EP 2030
It's not very difficult. CAUTION: HIGH VOLTAGE TO LAMP! ***BE SURE TO UNPLUG MACHINE BEFORE ATTEMPTING REMOVAL!
1. Remove 2 silver screws on plate that aligns your original -on left side of glass. (note: if ADF on machine, there will be two small springs under this plate, be careful to keep springs when you remove the plate) 2. Carefully remove glass by lifting slightly and sliding to the front. 3. Grasp carriage with lamp and pull to the right.
4. The lamp is held by tension between two silver lamp terminals. You can press (hard) on the rear terminal toward the back of the machine and the lamp will release and drop onto the reflector. Or, if this is difficult, remove the screw(s) on the black plastic housing that holds the silver lamp terminals. Once loose,
slide the lamp to the rear until you can lift the front up and out.
5. To replace the lamp, USE CAUTION NOT TO TOUCH THE NEW LAMP WITH YOUR BARE HANDS! The oils from your hand can cause problems later. Use rubber gloves or wrap a paper towel around the lamp when handling. Slide the lamp all the way into the rear hole until you can get the front of the lamp into it's hole. Then, maneuver the lamp onto the front terminal
while pressing the rear terminal until it's wide enough to accept the lamp. (or, if you removed the black housing, catch the lamp socket with the terminal then pull the housing toward you until it seats into position where you can reinstall the screws). 6. Replace the glass being careful to get the right side under the two metal spring clips. 7. Reinstall the original stop plate located left of the glass with the two silver screws (and the springs if ADF is attached). 8. Plug it back in, turn it on and away you go.
Anonymous
  • 180 Answers
  • Posted on May 03, 2009
SOURCE: TOTALLY DEAD
CHECK THE FUSE ON CONTROLL BOARD, CHECK THE CONTINUITY OF THE LOW VOLTAGE TRANSFORMER.
Anonymous
  • 43 Answers
  • Posted on Jun 16, 2009
SOURCE: I need to know what kind of color ink cartrige
Go lto market and ask for Minolta EP 3170 color toner or color lase toner
The witch
Francisco Mauricio G
  • 1551 Answers
  • Posted on Jun 03, 2010
SOURCE: nothing happens
Check the cord feed onthe part when it comes to the iron sometimes there got cable broken on the inside
Does anyone actually know what the procedure is to clear an SC35-02 .I haven't worked on one of these in 10 years DI650 Minolta copier
Power off the machine power on with the 2 and 5 depressed. Then go to soft switch set 3-1-1 if the code comes back its the fuser have a tech look at as it can start a fire ruining a perfectly good day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Minolta EP 2030 error code C05 how to reset
open the front door with power on in the upper left you should see a small panel remove the cover, press the small switch wait for ready to copy, if the code comes back do not reset the FUSER is bad it can start a FIRE ruining a perfectly good day!!!!!
Display error co500. Please help?
Open the front door, with power on. upper left small access cover remove and press trouble reset switch if the code comes back DO NOT RESET means a problem with the fuser (The hot Part) it can catch on fire that will ruin a perfectly good day. Have a tech come out look at it. He need to be old school that is a legacy Minolta machine, Now KonicaMinolta. For parts try this site.
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Parts such as fuser lamp, thermistor and thermostat
Minolta ep 6000 error code 410
Sir/Mam the bright light under the big glass is the problem it is not coming on or is having problems. See about replacing the lamp or the circuit board associated with that lamp. To reset open front door to your left is a small access cover remove and with machine on press the trouble reset switch. If the code comes back get a new lamp and or board
Minolta EP 3170 C8 code
check the paper draws
2helpful
I have a Minolta EP 3170, and I'm getting a paper jam every time I try to do a copy. The jam occurs right before the drum. Upon inspection, I first though it was the opto-switch near the drum because the...
Try making a copy from the manual by-pass tray. If that works, your problem is with the paper pick up & feed from the paper cassette. Odds are if that is the case you will need new feed rollers. Which clutch did you disconnect? There is reg. & pre Reg. & the developer drive clutch? This is a old copier, you may not find the parts for it. It is a Bear to work on......... I have not worked on one in about 15 years. It is basicly the same engine as a EP 4010 & EP 3090?
Date 18th May 2010 Dear Sir What is the
THEY ARE BASICALLY THE SAME MACHINE THE 1085 HAS MORE FEATURES.THOSE MACHINE ARE ABOUT 10 YEARS OLD AND PARTS ARE BECOMING HARD TO GET. I WOULDNOT BUY EITHER.GET A NEW DIGITAL COPIER AND YOU WILL BE ABLE TO PRINT FAX SCAN AND COPY AND PARTS WONT BE AN ISSUE FOR MANY YEARS
On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Do not know what Kind of color cartrige does a Minolta EP 3170 us
Good luck finding the separate developer units for this obsolete machine if you don't already have them.
If your just looking for color toner you may get lucky doing an internet search for the following item number: 8916361 - BLUE TONER
I need to know what kind of color ink cartrige does it take for a Minolta EP 3170
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Daniel Blask
Daniel Blask
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
