This might be due to the hardness level of the supply water.
http://laundry.about.com/od/laundryproblems/fl/What-Causes-White-Residue-On-Washed-Clothes.htm
or as
my wife has told me You may need to dilute the detergent with water first before adding the clothes. If a top loader add detergent- start wash cycle then when tub 1/4 filled with water then stir water and detergent and then add clothing.
Something is contaminating the water, what that is is the question here, have the water tested.
There are a lot of causes for that issue. Overloading, too much softener, bad drain pump, dirty drum, hard water are some of the more common ones.
Saturate an old cloth with white vinegar. Alternatively, you might use petroleum jelly on the cloth to remove the mold.Pull the gasket out gently with your hands to reveal the mold and mildew buildup inside the folds of the gasket.Wipe the mold away from the gasket with the cloth. Continue working to wipe away all mold from the folds of the rubber gasket.Dry the folds of the gasket with a dry cloth when you finish removing the mold.Repeat this procedure at least once per month to prevent mold and mildew from forming. If you notice mold occurring more frequently, clean it off when you see it.
