SOURCE: replace drain hose on mod LW6501W2 washing machine
Enter model # at www.appliancehelponline.com for diagrams and illustrations.
SOURCE: dish clean light flashing and
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run yourdishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Please take a second to rate your experience. Feel free to repost again if you have more questions.
Have a great day!
Many or even most washing machines will not run if the door lock switch is not working. Open and close the door a few times to see if the light stops flashing. You could press on the door where the latch is and see if that makes a difference.
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
