Exercise & Fitness Logo
B
Brian Romine Posted on Jan 10, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After transport, older Landice L7 exec trainer shows "Safety Shutdown Communication Error." 5-pin plug into "control panel" into lower board is loose. Upper board connection seems fine? Fix?
Electro Med Services
Level 3:
  • Landice Master 6,694 Answers
  • Posted on Jan 10, 2017
Landice Master
Level 3:
Answers
6694
Questions
Helped
1869667
Points
21433
If you wish to get some details; visit the site linked here. Pull up older posts..... http://electro-medical.blogspot.com/
What is the problem with the landice l7 when you the code CE
Communication Error between upper and lower board generally produced by a physical disconnection between harness and the the apparatus. Reseat the harness.
My landice 8700 programable is showing an L5 error and does not run how do i replace the switch that is bad with this treamill it only has an up and down button for more or less speed
LS Error on Landice L-Series Treadmills with Belt Movement Probable Cause A LS error on the Landice L-Series treadmills can also look like L5 and this error code means there is a loss of speed signal. This error can occur with belt movement but speed will not increase. Causes for the LS or L5 error with belt movement are:A) Speed sensor is out of adjustment
B) Speed sensor is damaged or faulty
C) Display cable is damaged or faulty
D) Improper speed control wiring Corrective Action A) Speed sensor should sit parallel with the flywheel and gap between speed sensor and flywheel should be within 1/16". Adjust speed sensor if necessary.
B) Inspect speed sensor connector to relay board. Check for pushed pins or loose wires. Repair or replace speed sensor assembly if necessary.
C) Inspect upper harness or display cable connector to relay board. Check for pushed pins or loose wires, giving specific attention to pin 5 (brown) and pin 9 (green). Repair or replace display cable if necessary.
D) Inspect speed control wiring:
  1. Checking purple wire from V+ on pwm board to P3 on the relay board
  2. Checking orange wire from P1 on pwm board to P1 on the relay board
  3. Checking brown wire from P2 on pwm board to P2 on the relay board
  4. Confirm P3 on pmw board has no connection
Correct speed control wiring if necessary.
Details about LS Error on Landice Series Treadmills with Belt Movement
With the L7 plugged in, and after pressing the start button, nothing lights up and the belt does not move.
looking for a qualified technician to check the connectors on the lower board specifically where the motor wires connected.
this part of the lower board overheats and sometimes there are false contact.
19helpful
Landice L7 gives me a L5 reading on the screen
Your L7 error looks like L5 , but its really LS which mean lost signal. Unplug unit take motor shroud off then plug unit back in wall outlet. When looking in front unit you will see a Motor control board and there are LED lit up one of them should be an amber light this is you speed sensor which is attached to the top of your motor. Manually rotate the fly wheel and see if that light flickers if it does then your speed sensor is working properly if not replace speed sensor. The next thing to look at is the motor brushes to if they are worn unplug unit you should see slitted caps on both side of motor remove them if they are less than 3/8" they need replacing. That for the most parts should take of your problem. Call Landice @ 1800-526-3423 have the serial# handy their on all the components in the unit
Landice won't start, it gives a L 5 error. I already replaced both chip boards. but the light on the board closest to the motor does not come on! Not sure if I got a faulty board? Is there any information...
I have a Landice L8 and the error code L5???
Landice treadmill 05 error code comes on when i hit start
Lites on control board read ( L 5 ) when machine is turned on.
the e1 symbol is an engineering error code for an electronics malfunction (actually is senses the motor not turning and giving an error. The most likely cause is the motor control board
www.twincityrepair.com
Top Landice Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Sportsmith LLC
Sportsmith LLC
ADMIN Andrew
ADMIN Andrew
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
