Computers & Internet Logo
Tarun Kumar Roy Posted on Jan 09, 2017
Show macadress of compaq presaiocq40 - Compaq Computers & Internet
fattiechef
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Mar 17, 2017
fattiechef
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
0
Helped
999
Points
33
Open the Windows Command Prompt. a. ... The MAC Address for each network card in the computer will display in the Command Prompt window. The PhysicalAddress: This is a 12-digit number also known as the MAC Address of your Network Adapter. The Transport Name: This is the location of the Network Adapter
cmd prompt: ipconfig (simple write that in command screen and it wil show you both IPv4, also will show the IPv6 , but v4 is what you need for the MacAddress.
HOWCAN FIND MACADRESS WIFI LAPTOP VOSTRO1500?
Open a command prompt ( Windows key + R to open Run box, then cmd), and type
ipconfig /all
and look for the wifi adapter. The entry labelled "Physical Address" is the MAC address. It will look something like 84-3A-4B-C8-E9-B7
(Your router might want it entered in the format 84:3A:4B:C8:E9:B7)
My compaq presario c700 laptop didnt shows the inbuilt webcam and it also shows a unknown Microsoft ACPI-Compliant System hardware. what i do
You can download the device drivers from the Compaq/HP WEBsupport/download page. Make sure
you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
www.compaq.com/country/cpq_support.html
1helpful
Hi my compaq keeps showing blue screen code ***
Please open the link below and follow the instructions to resolve the issue
http://support.microsoft.com/kb/324103
Hi,i have a hp g6000 laptop with a compaq f700 motherboard fitted.the laptop works fine,but does not recognise the dual core processor or wireless card(not show in device manager with wireless button on or...
The reason it shows the compaq logo is because that is the motherboard you have installed. HP is just your case if I am reading your question properly. Did you custom build this? Which processor is in it? Probably the wireless card isn't being recognized because of your 64 bit operating system. Windows 7 has a lot of hardware driver problems right now.
My compaq presario m2000 shows "scan disk error"
If you have valuable docs on that drive that you haven't backed up, then the $90 will with 99% certainty get that part of the drive back that is still readable.
http://www.grc.com/sr/spinrite.htm
Compaq 40/80 GB DLT DRV Problem
why run w2000.?
what external drive, made by whom.
USB drive?
what PC? HP what? HP compaq what.
what usb port usb 1, 2, or 3.>?
can you copy files to it using windows explorer, (my computer)
if not the drive is failing
or the power pack on the drive is missing or not rated at 2amps.
i cant see your setup so can only guess what is there.
details matter
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
