Motorcycles Logo
M
MONTANA Posted on Jan 09, 2017
HEY DO INEED A BATTERY TO START MY CHINESE SCOOTER OR CAN I JUST KICK START IT TO MAKE IT RUN WITHOUT IT
My scooter suddenly won't start anymore.
Flat battery. Unless the battery is fully 12.2 - 12.6 volts, it won't start with the electric start. If the voltage goes below 11 volts, there is not enough power for fuel injection and ignition assuming your mystery scooter has fuel injection. Connect it to a battery charger for 8 hours.
How to fix my razor scooter e100?
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
I have a 4 stroke Chinese scooter. The engine is ...
My 50cc Chinese scooter motor keeps fowl ing plugs out
May 14, 2017 • Motorcycles
Jonway eletric start and lights problem.
Recommend contacting your nearest authorized service center directly or online here:
http://www.jonway-motor.com/contact.html
1helpful
So, my 150cc Chinese scooter has been acting like the battery in really low. I have been kick starting it for a couple of weeks. Today, the kick start level disengaged so now I'm really stuck. I got a...
Did you remove the battery from the scooter before charging? The scooter circuitry may be giving the charger false readings.
Can you try to jump start the scooter using a car and some jumper leads? If it starts that way, then your battery is dead.
Top Motorcycles Experts
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Motorcycle Expert? Answer questions, earn points and help others
