Electrical Supplies Logo
R
Raymond Carpenter Posted on Jan 08, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an old Wacker Portable Generator that when I pull the start cord, I have no resistance. It doesn't seem to be connected to the motor. How can I fix this?
Generator Guru Parts
Level 3:
Master:
  • Electrical S... Master 286 Answers
  • Posted on Jan 09, 2017
Level 3:
Master:
Answers
286
Questions
Helped
148714
Points
1274
It could be a few things:
1) The recoil has broken and needs replacing - remove recoil and inspect
2) the valves need adjusting - 0.015 inches on intake and exhaust, if not running right 0.020 inches for exhaust.
3) The piston rings are shot - To check remove the cylinder head and add a tablespoon of oil to the top of the piston. Leave overnight. If it disappears you need to replace the piston rings.
We also we sell parts if you need them :)
https://www.generatorguru.com Parts Spares for Generators and Small Engine Machinery
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Jun 15, 2009
SOURCE: i need to replace a broken pull cord on my
just remove pull cords housing the rope is right ther.
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 02, 2009
SOURCE: voltage on portable generator is running high appx 135vac
What do you consider high? If the voltage is between 115- 125 volts, it's fine.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Anonymous
  • 1922 Answers
  • Posted on Oct 07, 2009
SOURCE: Unable to pull starter cord at all
pour some gas/oil mixture down sparkplug hole and let it soak and see if the rings are carbon blocked
thesnooper
  • 342 Answers
  • Posted on May 10, 2010
SOURCE: I broke the pull cord on my generator; how do I
you should remove the housing usually 4 bolts
dont remove anything else then look at the pully and remove the old chord tie a knot in the new chord and slot it into the hole on the pulley
you should then see a notch in the edge of the pulley this is for the chord to sit in while you turn the pully enough times to tension the recoil spring once tensioned enough so that it recoils all the chord slot the chord through the hole in the outer casing through the pull hande and knot it job done then refit
Tony Masur
  • 10 Answers
  • Posted on Dec 23, 2011
SOURCE: troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
your cord is too long is why its binding up ,,,on the tee hand where you put your hand on to pull,,,,take a screw driver and push up the tied knot out and away from the tee handle,,,,take and make another knot about 8 inches and pull the cord back into the tee handle then try it again. Most have a long rope, cord etc for maximum pull,,sometimes they go overboard on the length and it binds up on the rewind of the recoil system
Testimonial: "Tony, Thank you for the help. You're right about the cord being long. It was a strain on my wrist to pull the length of the cord."
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
My electric demo hammer stopped working. Wacker is the brand name. The switch tests good.
Does it have brushes that need to be replaced. Check with a power tool supplier for advice/parts to repair
Good Luck
1helpful
No electric output, how do I diagnose, capacitor, proper winding check etc.
Have you tried flashing your generator? Sometimes the magnets in the generator loose their polarity. Google and YouTube "flashing a generator"
HFLASHING the GEN
Sometimes the magnets lose their polarity. This worked on my brothers $1200 gen. Its worth a try. Good luck!
Check all wires/connections first, Then try this-
(Remove spark plug wire first!)
To flash the field on a small home use generator, get an ext. cord & cut off the female end of it & strip the wires & connect the wires to a 12 volt car or lawn tractor battery, & plug the male end of the cord, into the 120 A.C. side of the generator.
Make SURE that the black wire which is POS/HOT on an A.C. cord, gets connected to the RED/POS. side of the auto battery, & the white wire on A.C. cord gets connected to the BLK./NEG. side of the battery. If the ext. cord wires are not black & white, then the smaller prong of the plug is the POS./HOT
Plug the other end of the ext. cord into the generators 120 volt side (**remove spark plug wire**) & pull the starter cord 4-5 times, then remove the ext. cord, reconnect the spark plug wire, start the unit & plug something of 120 A.C. volts in to see if it works. Then let it run for about a half hour with 2 - 150 watt lights to help re-generate the unit.
Read more:http://www.doityourself.com/forum/outdoor-gasoline-power-equipment-small-engines/188605-recharging-generator-field.html#ixzz29QwjlAOWere's one way-
2answers
I already broke one recoil starter assembly on my Astra Korea 3 kVA generator. I can start the generator, but with great effort. It takes about 6-8 pulls, and there's so much resistance that I can actually...
The easiest test to run on the generator is to remove the spark plug and see if it pulls easier. If it does then it is a compression problem. I doubt that is the case. If it does not then you need to take the generator off the motor and see if it still pulls hard.
If my generator shut off due to low lubricant will it reset automatically? If not is there a reset valve/button?
The pull cord is like a starter on a car (separate from the motor/engine). If the pull cord will not turn it could be because the motor/engine is seized.
All the fuel leak into the oil pan
my wacker 5600 generator leaked gas into oil. What would cause that
2helpful
Troybilt 5500 generator pull cord locks up...just had it for one year...cord was very easy to pull @ first...but lately it locks up when I try to start it...any suggestions?
How do i replace pull cord on craftsman weed wacker model 316.791080?
is the pull cord in the front of the motor if it is it is not worth fixing it will take about two hrs to fix the motor will have to be pulled..
Jul 18, 2011 • Garden
4helpful
2answers
My 5700 watt 11 HP McCullough generator wont start. I'm getting good gas to the plug but no spark.
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Top Electrical Supplies Experts
Sean Wright
Sean Wright
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
