Televison & Video Logo
A
Alice Anderson Posted on Jan 08, 2017
My husband is ill. I do not know how to program a vcr. Where can I learn to program a Disney VD 2100?
I need to get a universal remote for the Disney VCR/DVD Combo Player, any recommendations?
Yes, do not bother with a Universal----at best it may turn set on/off and work volume but it will be missing many key features needed.
"Universal" remotes are hardly universal in this sense.
Best suggestions would be to GOOGLE the model number of the set with "original remote"----not a universal.
If you have the original but it does not work most repair shops for a tiny fee (we charge 5-10 if fixable) can deal with the repair.
If lost try to find an original unless you want VERY BASIC functions and you are gambling that the universal will even program for this unit.
Let me know if questions----GOOGLE IS YOU BEST SOURCE FOR RESEARCH ON THIS ISSUE.
1helpful
I replaced my TV and now my VCR Zenith Model 2100 will not record
Digital TV can use component video and stereo connections to record on analog VCR. Analog VCR needs DTV converter to record digital TV channels. VCR play back use AV channel on TV.
Need help to unistall
go to contol panel click on add remove programe from there u can uninstall the game
I have apex dt-250a digital converter box and I lost the remote. Purchased RCA universal remote and I have not a clue what codes I need or how to enter them. Can you help?
I programmed a Radio Shack 5-in-one remote to my Apex DT-250. Select cabel/satelite, hold p until the light blinks twice, then enter the code 0749. It works! If your universal remote uses a three digit code, use 749. If it uses a five digit code, use 00749. I HAVE A PROBLEM THOUGH... I don't know how to scan for channels! It says "please do auto channel search", but how do I do that? Please, if anyone has this answer, let me know. I finally programmed the universal remote, but it's basically useless without being able to do an auto channel search.
2answers
My daughter's disney dvd player wont play disney dvd's any ideas?
I would suspect dirt, either on the disc itself or in the player. The discs and laser head need to be clean to do their job properly. If they are too dirty to operate correctly the machine simply gives up trying as though there were no disc loaded at all.
Need to program my TV-VCR 9" combo using the RCA remote RCC311w
Try pressing the VCR button and see if that works.
Alternatively use one of these codes (For RCA VCR):
2000, 2003, 2007, 2013, 2021, 2022, 2055, 2056, 2082, 2083, 2084, 2085, 2086, 2087, 2088, 2089, 2090, 2091, 2100, 2107, 2115, 2120, 2125, 2133
Two methods of programming RCA remotes:
A: If your remote has a "Code Search" button:
Press and hold the button until the light comes on and stays on, then release and press "VCR", Enter the last 3 numbers of the code (no using the first number 2).
B: No code search button:
Press and hold the device key, while holding it put in all 4 numbers of the code, then release the device key, the light should go out.
Lost booklet
link to codes is at bottom
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
5helpful
8answers
Universa remote codes.
I used Memorex code 135
3answers
I need to download a manual'
You can download the manual from here.
Top Disney Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
