Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
I wish there was a tutorial on this. Is one of the hardest servers ever to thread!
I just got the same machine and I can't get the lower left looper to thread correctly I have a manual but it does not show how or where to place the thread when you are done meaning around the upper looper thread
I nt finding tutorials on you tube to show it for this model
I can't find any
