Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
SOURCE: lcd tv screen stays black, but with sound
just open up the tv 2 the main bord then look for a littler green button press it and then plug it in and it will work i did it 2 mine
SOURCE: Can somebody pls. help...our tv Samsung LN40A550
This is a very common problem. The power supply board has failed and needs to be replaced. You can call 1-800-samsung to find out if this problem will be covered under a warranty and the nearest service center. I replaced at least 150 power supplies last year.
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
