Home Logo
Sheila Wolfe Posted on Jan 06, 2017
How to operate Ariel Platinum AM154 Whirlpool Bathtub, 59", Left Drain
1 Related Answer
uspartscente
US Parts Center
  • 719 Answers
  • Posted on Aug 18, 2011
SOURCE: The wall switch control for
pretty much bet on the fact that the pump has burned out. You are very lucky it did not set your house on fire. There is much friction when the pump is on and there is no water in the wet end to keep the seal cool. You will need a new pump. What model pump do you have? Find your Pump
How to fill an ariel bathtub
The proper way to fill the Ariel Bathtub is to turn on the faucet that is near the tub with warm to hot water to your liking. Once it is above the highest jet in the wall of the tub, if your Ariel tub is a Whirlpool model you may operate the jets.
Rod
US Parts Center
888-521-6183
I need my bathtub resurfaced
For bath refinishing there are several companies out there that do that. My suggestion is to do a google/bing search and see what comes up in your local area.
Rod
US Parts Center
888-521-6183
2answers
I have an ariel whirlpool tub that has an E1 error problem
Have never heard of that error code. What brand of bathtub do you have?
Rod
www.uspartscenter.com
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
2answers
How do I install a whirlpool bathtub?
here is a link to the some installation and operating instructions.
basically you need to put a 2" x 2" runner under the lip of the tub along the three sides of the tub that touch the walls to support the lip of the tub. that pretty much covers it.
Swanstone Veritek BA-3060 alcove is shorter than the BT-3060 tub
that sounds like the correct dimensions. there needs to be some slack in there so the sealant can be placed around it.
Bath Operating Cost
No more than any other household major appliance. The motor, heater, and any other options are standard 110 volt so the average cost to operate your whirlpool is only pennies a day.
Top Whirlpool Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
