SOURCE: Charger Repair for Ryobi drill 14.4 volt
It has been my experience that when one component of a board goes bad that something else is wrong and even replacing that part still will not work. But you can try contacting Ryobi direct at their website and see if their tech service can get that for you. They are very vague when it comes to some of their products so good luck. Also as a thought if you have a tool repair facility in your area you might contact them and see if they have a junk charger laying around that you can scavenge for parts.
SOURCE: Missing fuse in RYOBI CTH1202 Charger.What size fuse .5,1.0 2.0 ?
that would be a 2.5 amp fuse , sincerely glenn
SOURCE: NEED A MANUAL FOR A RYOBI BATTERY CHARGER
This link should help in finding a manual. Good luck. http://powertool.manualsonline.com/manuals/mfg/ryobi/ryobi_battery_charger_product_list.html
SOURCE: Owner's manual for Ryobi 18 Volt Lithium String
Hi .. try this site for the manual .. just answer the question in the pop up and then you can view the file ..
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi_outdoor/rgt2500.html
Please Vote !
SOURCE: ryobi 18 volt battery charger
If replacing the charger is not an option, open it up and check the fuse. Another item to check is the current limiting resistor, color coded red-red-black.
If you need more help come back.Post /
thumbs / testimonial are
welcome!
