Ricoh Aficio BP20 Laser Printer Logo
A
Angela Lewis Posted on Jan 05, 2017
Ricoh bp20 can't load smartui code 193. What does this mean and how do I fix it?
1 Related Answer
don_farr
Don Farrell
  • 1018 Answers
  • Posted on Feb 15, 2010
SOURCE: I need to reset toner cartridge Ricoh BP20
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
3answers
1670: unable to load module d:iss setup.dll,error code:193
this game was not released for the PS3 and may not be compatible with the newer hardware.
1670: unable to load module d:\iss setup.dll,error code:193
get current PS update when you turn on system - if the update doesn't automatically load - go to system - system updates - follow instructions on machine.
I`m using a PC with win7 and a network printer Aficio BP20 Series PCL 6 its only print in B/W not color why? Need help.
if you are using the proper driver there should be a setting if you click the properties button when you hit print on the computer. from there you can set it to print in color.
1helpful
Where can I download the driver for Mac os x 10.5.8 to run a ricoh cl7200 please and what kind of size will the down load be. Thank you
Hi, you can get the CL7200 driver for a Mac OS X 10.5 from the Ricoh website here:
http://ricoh-usa.com/downloads/downloads.aspx?d=ds
Just search for CL7200 under Drivers, and then agree to the site's terms of service. The Print Utility download for the Mac is 319 KB; you can click the link under Download. You can also download the PPD Installer (193 KB) and the PANTONE Color Palette (11,261 KB).
How to add Ricoh Aficio BP20 to new laptop
Hi, go to Ricoh-USA.com to download the printer's driver software. Go to the Downloads section, choose Drivers, and search for your printer and operating system. Download the driver and unzip it if it is zipped, then go into the Printers section of your computer's Control Panel, click Add Printer, and follow the prompts. Windows will walk you through the installation process.
2helpful
I have a aficio bp 20 series pcl 6 printer its failing to print.
Is it only the 'red' light or is there another one also lit?
If it is on steadily, it should be related to a paper jam, if blinking, then related to Data in, and no paper.
Manual is here to check what the status lights mean (copy this link into your address bar):
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/bp20n/bp20nen.htm
** info is on page 6.21
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
