Check the end sensing switch on both side.
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
SOURCE: the belt is not turning
the weight capacity will be in your manual with the motor running you may have disslodged the internal belt or may have even snapped it. you will have to take the cover off and check it.
SOURCE: Same exact thing
The incline is trying to calibrate if you let it do it till it is done it should stop. If it continually trys to incline every time you use it there is a incline sensor out of position or the console is bad.
SOURCE: My proform 515s Crosswalk treadmill works for a
1. Inspect belt and deck. The deck should be smooth. The belt should have a consistent feel from side to side (a belt can be worn out without any sensory signs of a problem). If you feel deep grooves in the deck or uneven wear on the underside of the belt, part replacement is necessary. Continued use of your treadmill may damage expensive electrical components. 2. To inspect the belt and deck visually or to clean underneath the belt before applying lubricant, the belt must have the tension reduced. Loosen the tension roller by following the instructions in your owner’s manual. Do not loosen the bolts in the tension roller too far or the bolts will come out of the roller shaft. This step may not be necessary for your treadmill model or belt and deck condition. 3. Contaminants are the worst enemy of your belt and deck. Some treadmills may have an excessive accumulation of dirt and contaminants. If these are trapped during the belt lube process, significant damage will occur. If contaminant removal is necessary, loosen the belt by following step 2, lay the treadmill on its’ side, and use a nylon brush to loosen contaminants that have accumulated on the inside of the belt. Clean the deck with mineral spirits in a well-ventilated area. Allow the deck to dry before lubing or tightening the belt. 4. After completing the steps above go to your local hardware store and purchase a can of silicone spray ( Pyroil, Napa etc ) attach the nozzle and proceed to spray length wise starting at the motor shroud to 2/3 down the deck repeat the process on the other side then re-tension the belt according to you owner's manual. Start unit and proceed to walk on it if the unit shuts down again then belt and deck needs to be replaced or your in the market for a new treadmill.
SOURCE: Proform crosswalk 397 will not incline
see the diagram, and RUN the software calibration for diagnose and troubleshooting.
lube the gear and racking from elevation motor, clean, and tigh any wires connectors:
test the main board, with the output voltage from board for input voltage motor. If there are NOT voltage the board is faulty.replace see the block diagram, how the main boad control about 80% of the machine motion.
God bless you
