Question about Samsung UN46EH6000FXZA 46 1080p 240Hz LED LCD HDTV
Need advice on color issue with Samsung UN46EH6000F TV
My Samsung UN46EH6000F began experiencing a full screen green tint suddenly overnight. Came on very quickly, wasn't a gradual issue. It's a translucent tint - you can still see moving video, no picture rolls or permanent lines or bars across the screen. Just full screen, even green tint. No on-screen diagnostic, color adjustment, restore default settings or firmware upgrades have any affect. I assume I need to change out a board. Between the TCon, Power Supply board and Main Board, I'd like to try and figure out which is the most likely culprit and try swapping it out first. I'm thinking TCON board but looking for some further input.
  • Samsung Master
  • 6,694 Answers
The TCON board or the LCD panel is Faulty , Can confirm by replacing TCON board.
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Posted on Jan 06, 2017
SOURCE:
Red Tint on Screen
This is normal and is a color calibration issue.
For correct color, NEVER use the "WARM" setting. Why? Too red. You cannot get REALISTIC or ACCURATE color using the "Warm" setting.
Since we are speaking of Samsung, first avoid the "Flesh Tone" adjustment. When things are set correctly there is no need for this adjustment. It is a quick fix and not for the "discerning eye".
1. First, access the "Color Temperature" menu. From here select "Cool2" or the coolest temperature setting.
Note: For Samsung use "Cool2", or if not available, "Cool1". Samsung has inadvertently increased calibration confusion by issueing TVs that have just "Cool1", and TVs that have both "Cool1" and "Cool2" :0[
For other brands, use "Cool", or "High", or "+6500k". Anything lower artificially reddens the picture and compromises detail.
2. Now return to the color settings and reduce "Color" to between 30 and 40 (on a 100 scale). The sweet spot is just near the place where the color rapidly washes out.
3. To round out the color palette, move to the "Tint" adjustment and ADD a couple (3-5) clicks to the GREEN.
Adding the touch of green is what is needed to take out the last bit of "pink" and will make all the tones and all colors display properly.
I hope this helps!
To further increase the quality of your picture visit
http://www.wowvision.tv/main.htm
Highdefjeff :0]
Jun 15, 2010 | Samsung LN46C630 TV
What would cause my jvc tv have a green tint
It sounds like you can have optical engine issue. That's if green tint was show up very gradually, until one day it really caught your attention.Normally some parts of the screen more green than other. It should get progressively worse. To solve this issue optical engine have to be replaced. It is pretty expensive repair if your TV is out of the warranty.
In case if tint appeared suddenly in one moment - you can try to check component cable connection on the back of your TV if you are using one ( green, blue and red colored). Sometimes it's loose or after disconnection people reconnecting it in wrong way.
Experienced tech will determine if optical engine is bad by running test patterns in special service mode. If green tint present on Grey scale - optical engine is bad.
Sorry for bad news.
Regards.
Russ.
Apr 06, 2010 | JVC AV-56WP74 56" Rear Projection...
Green tint in the color on my big screen tv
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 12, 2017 | Samsung Televison & Video
While watching tv a moment ago the screen began to fade and now the picture has a blue green tint to all the colors. I have a Samsung DLP tv
Hi,do you hear buzzing,whirling or high pitch sounds? if you do it could be an issue with the color wheel If the TV have the infamous blinking lights problem and you're replaced your lamp without success, it's most likely a problem with your color wheel. The Samsung color wheels spin anywhere from 6,000 to 15,000 revolutions per minute (RPM’s)--It is one of the few consumable parts in your Samsung TV. The average life expectancy from our data logging shows the Samsung color wheels are fairly reliable with a MEAN average of 5-8 years .It could also be the DMD board this is how it works:http://electronics.howstuffworks.com/dlp1.htm One simple way to test if it is the DMD board it's to display thew menu,if menu is also affected that for sure what it is.God bless you!
Sep 30, 2009 | Samsung Televison & Video
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Samsung 61" DLP TV color issue
The color wheel is either defective or needs to be re indexed.
May 18, 2008 | Samsung HLN617W 61" Rear Projection HDTV
Green color on Samsung ln-t4042
If the whole screen has this tint problem, there is nothing you can do. It must be repaired. You will need to take it in for service.
Mar 15, 2008 | Samsung LN-T4042H 40 in. LCD HDTV
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Sep 10, 2007 | Sanyo DS27910 27" TV
Samsung UN46EH6000FXZA 46 1080p 240Hz LED LCD HDTV Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
