If you take off the platter, then undo the plastic board covering and protecting the circuit board...then once you have access to the circuit board...there should be a little blue knob, usually located top right...its basically a matter of turning it untill you are happy with it, unless you have a little mark on the blue knob and the circuit board...if you or someone has done that, then that will be the master setting, of +8/-8 pitch
Hi, please clarify, has the circuit been modified to change speed. You should able to set it to normal with the fader???
