Let's say a Ferrari LaFerrari, about 800-HP but the electric motor produces 120 KW for a total of 960 HP does it make sense to say the electric motor produces 120 HP? 160 HP ***** NOT 120 HP****
HP is just mechanical energy KW is electrical energy (mechanical and other) both are valid - conversion is .747 so yes car has total 960HP of which 160 is electric by a 120Kw motor ...
No. We all can't be versed on every aspect of our world but some parts are important to keep us from falling into poor investments and scams. There are several laws of thermodynamics, essentially how energy works in our world and are a fundamental part of our understanding of physics.
One of those laws suggests that energy like arithmetic will not change unless something operates to change the numbers. The energy that is put into a system (2 + 2) is always going to equal the energy that goes out of a system (4) So just as 2 + 2 is not going to suddenly equal 5 or 6 the energy we put into our system is not somehow going to create more energy. The best we can hope for is to create a system that will somehow gather more energy from another source like solar panels. In this case it is like saying 2 + 2 + 1 equals something more.
In your suggestion you want to add hydrogen to a generator and then use the resulting electricity to produce hydrogen by splitting water and then use that hydrogen to run the engine. But you are leaving out some of the elements. The engine is probably no more than about 25% efficient. That means that 75% of the energy in the hydrogen fuel you use is used to create heat and is lost to friction. So far your equation then looks like 2 + 2 - 3 . The generator also loses some energy to friction. Add to this it takes more energy to split water into hydrogen and oxygen than we recover when hydrogen and oxygen combine to produce some excess energy. So in every step along the way we are losing our desired goal to losses in energy like heat and friction.
But even if the system were somehow perfect it could not be any more perfect than to lose no energy. You will not be creating new new energy with such a system. Even if we could get it to run forever the system is not going to give us new energy we could use for something else as every bit would be used to run the system. This is why we say that efficiency can never be greater than 1 or 100%. And we can not have "over unity" or "perpetual motion" machines.
If we want "free energy" what we could do is make solar panels. And then use those solar panels to gather additional energy from a source outside the system and then produce hydrogen from solar energy. What we can't do is use a solar panel to produce electricity for a light that shines on the solar panel as once again this would be a closed system with no energy flowing into the system.
When it comes to energy systems look for the source of the energy. If it is supposed to be coming from inside the system perpetually then it is likely a scam. If there is an outside source it may be useful depending upon the economics and how much energy we get relative to our energy investment.
Steam or electric are probably cheapest TO RUN... But most expensive to buy.... Butane would probably be next... It is actually a Mixture of Butane, Methane and a few others... In Australia it is the same as we use for the BBQ..... This would probably be next.... but unless the car is Factory converted,... then you will probably need some Petrol/Gasoline just to start .. You use maybe 2 or 3 Cupfuls each time so you don't use Much... It is also a Good backup if you run out of LPG....... The rest... it depends on th e Government and Fuel Companies which one is cheapest but what it SHOULD be id From cheapest up... Diesel, Unleaded, Premium Unleaded
Forget the rest... They would be cheap to run but the conversion would be so expensive it would be not worth the effort
Not at all. The concern over Electromagnetic Fields (EMFs) popped up in the mid-1980s, less than a year after I started working for an electric utility. A study was being data mined and an association popped up between electrical workers and two kinds of brain cancers: gliomas and astrocytomas. That was all - a doubling of frequency for each of those cancers in the electrical workers in the sample.
That was mighty scary. Those are really nasty cancers and EMFs are everywhere - not so much around electric meters (especially modern digital ones, which do not have motors) but certainly things with open loops, like electric blankets. My job often took me into high and extra high voltage (230-500 kV) substations, where the EMFs are so high that touching a grounded fence produces a painful shock.
A few years ago (time flies so I don't remember when it was but probably about 5-10 years ago) a much larger study found no association at all - the other was a statistical cluster. That does not turn back the clock on Euro regulations, though. The World Health Organization (source) leaves it open-ended: "To date, no adverse health effects from low-level, long-term exposure to radiofrequency or power frequency fields have been confirmed, but scientists are actively continuing to research this area."
