Home Security Logo
Pat Mineard Sr Posted on Jan 04, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a brinks safe that has a combination lock and a key but i cant remember my combination and was wondering how I can reset it. Model number 5059
Lawrence Oravetz
Level 3:
  • Home Security Master 10,558 Answers
  • Posted on Jan 04, 2017
Lawrence Oravetz
Level 3:
Answers
10558
Questions
Helped
2695716
Points
29284
Each Brinks 5059 safe has a different default combination, so to get the original combination you must either contact Honeywell (the parent company for Brinks safes) at 1-800-223-8566.
You need to send them a notarized letter showing safe ownership in order to get the master combination. When you call Honeywell, you will need to provide your safe's model number, the serial number (found on the right of the safe, near the model number), and your key number.
1helpful
We have a Brinks fire resistant safe model 5059/5063 and can not get into it. Lost the key and the combination. What can we do? Joyce
You do not need to go to a locksmith - you can get a new key much more inexpensively by contacting Honeywell (the parent company for Brinks safes) at 1-800-223-8566
When you call Honeywell, you will need to provide your safe's model number (5059) and the serial number (usually found on the right of the safe, near the model number).
At the company's discretion, sometimes they require a notarized affidavit confirming ownership. There is a fee for a replacement key (it was $15 last time I checked, but may be higher now), but it is much less expensive than going through a locksmith (who will generally just do the same thing as described above!)
Lost combination model 5059 brinks key and combination safe
if no key -- try to contact the manufacturer customer service,. be near the safe when calling in, they may have some number or other reference on the safe to help you out with that one... alternatively your local locksmith could assist (for a fee)
Best regards
Ck
4helpful
2answers
Brinks fire resistant safe model 5059 instruction manual
Here is the turning sequence:
General Turning Sequence Instruction NOTE SAFE MODEL 5054/5055/5059/5080/5081/5084/5111/5190/5195/5575/5700/5702.
Combinations consist of FOUR (4) positions (numbers).
BEFORE YOU START
Before you begin, please clear all settings by turning the dial CLOCKWISE (to the right)
three times. We also recommend to try the procedure with your safe door open first. Then
follow these steps:
TURNING SEQUENCE
1. Start the dial on 0 (zero).
2. Turn the dial to the RIGHT, passing your first combination number FOUR (4)
times and stopping at that number on the fifth time around.
3. Turn the dial to the LEFT, passing your second combination number TWO (2)
times and stopping at that number the third time around.
4. Turn the dial to the RIGHT, passing your third combination number ONE (1) time
and stopping at that number the second time around.
5. Turn the dial to the LEFT, to the last combination number and STOP.
6. Insert the key in the cylinder lock and turn RIGHT to open.
Your safe should now be opened.
8helpful
3answers
Brinks safe
As I understand that safe has four numbers to the combo. 1) turn the dial to the right passing the first number 4 times stopping at that number the next time around. 2) Turn the dial to the left passing the second number 2 times and stopping on that number the next time around. 3)turn the dial to the right passing the third number 1 time and stop on that number the next time around. 4) Turn the dial to the left stopping on the last number. 5) Insert the key into the cylindrical lock and turn it to the right.
207helpful
16answers
To bad you dismantled. Here is the turning sequence:
BEFORE YOU START
follow these steps:
TURNING SEQUENCE
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
