Step 1: Open the Safe Door
Enter the Factory pre-set code of 1 -2 -3 -4 -5 -6 and open the door. ==== or your personal combination
Step 2: Programming
IMPORTANT! The following must be done with the door in the
OPEN
position with your locking boltsextended.Please Note: Between each step you have
4 seconds
to proceed to the next step.
1. Enter in 0-0-0-0-0-0 six (6) zeroes.(This will put you in programming mode.You will hear a double beep.)
2. Enter in your existing 1-2-3-4-5-6 six (6) digit combination.(You will hear a double beep.)
3. Enter your new six (6) digit combination.(You will hear a double beep.)
4. Enter your new six (6) digit combination again.(You will hear a double beep.)
5.Wait approximately 10 seconds and then enter your new combination.
6. If the procedure was executed properly, you will be able to rotate the handle.
7. If the handle will not rotate and the safe will not open, the procedure was incorrectly executed and the combination is still 1-2-3-4-5-6.Leave the door open and start over with Step 2.Entering in the wrong code will result in three (3) beeps.Entering the wrong code four (4) times will result in the keypad shutting down for a five (5) minute time-out.The battery must remain connected. Removing the battery will not over-ride the shutdown period.
Most likely it will not close because the lock has been activated while the door was open. Probably need to take it to a locksmith.
