SOURCE: The hood latch cable is
Find a pickup the same year and model. With this hood open, Take a coat hanger and bend the hanger to the correct shape to snake into your pickup and hook onto the hood latch. Practice a little on the hood open, partial closed etc until you are comfortable snaking this into the latch.
InMrFixIt
SOURCE: I replaced the hood on my toyota corolla 1998 and
look to see if u have slots in the hood were u can slide the hood up and down thats how u adjust it
SOURCE: how to change transmission fluid and filter in my 2003 kia sadona
ITS VERY MESSY UNLESS YOU HAVE A BIG PAN TO CATCH ALL THE TRANNY FLUID, BRING IT TO A TRANNY SHOP INSTEAD, PAY SOMEWHERE FROM $75 TO $100
SOURCE: hood wire is out from the latch at the hood end
first, try smacking the hood at one of the front corners while someone else pulls the release handle. or even after you've pulled on it. if that works, once open, adjust and lubricate the hood latch assembly. if it still won't open, and it's the cable and not the latch you'll have to replace it anyway, so instead of removing the grill, cut the cable behind the pull lever under the dash where you can reach it. then skin the outer cable insulation away from the actual steel cable exposing an inch or two of it. then holding the insulation and plastic housing with pliers, grab the steel cable itself with pliers and pull it to open the hood. then replace the cable. the further you can reach up under the panel the better your chances of getting past the broken part of the cable and avoid removing the grill. you might also be able to gain access from up under the car if you're lucky.
