Error code E05 indicates a problem with the belt speed. Unlikely it is a bad sensor given the smell and heat. Hopefully it is under warranty.
There are troubleshooting tips is the user guide. Here is an assembly model that serves for both the ZR8 and ZR9.
The following indicates how to adjust speed and lubricatrThe first one may help narrow down the problem but the others may prove more helpful. If adjustment does not help, you likely will have to try a service tech.
https://www.youtube.com/watch?v=a2FCo3JTO00
E02 error code: control board or motor issue. Test the motor first to check if the motor can runing normally. If motor is normal, replace the control board. E03 error code: 1,Turn on the treadmill , motor running a few seconds then stop and console board shows E03, probably the Speed sensor issue.
https://anytreadmillparts.com/pages/treadmill-error-code-troubleshooting
First of all check the speed sensor.
If you wish to get some details about treadmill error code and troubleshooting ; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Precor Error 03, Memory, RAM, EEPROM Test Error
Probable Cause
This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action
If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
Hola buenas noches quisiera que me pudieran apollar con una caminadora lime pro modelo D5.0 . El tablero realiza sus funciones pero la banda no gira al precionar Star no me arroja ningun c?digo g se los agradecer?a
"E03': No sensor signal. Sensor wire is faulty, replace the sensor wire. Magnetic sensor wire is not working replace see the diagram attached.However clean it. and tight the connector very well.God bless you
Dear Sir: This is probably a faulty speed sensor or the speed sensor is not plugged in properly. Its also possibly a faulty motor control board or lower board. The error codes will differ between makes and models but could be e1. . sincereley.God bless you. ernesto cuadramanagua, nicaragua c.a.
