Home Logo
Rita Barrett Posted on Jan 01, 2017
We have a Koehler jacuzzi tub that has been installed for about four years but never used. When we push the start button the jets operate for about 2 seconds.
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Dec 12, 2008
SOURCE: Only 3 of 6 jets in jacuzzi tub working
Make sure the jets themselves are fully opened. Some models you can turn individual jets on & off
Anonymous
  • 145 Answers
SOURCE: jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Anonymous
  • Posted on May 20, 2009
SOURCE: Jacuzzi tub works.....sort of.
motor for tub does not run checked electric its ok.. is there a reset button and does there have to be water in the tub?
bwbconstruct
  • 23 Answers
  • Posted on Jul 20, 2009
SOURCE: We've had a whirlpool tub with jets for 2 years.
check behind the access door for a air tube that goes from motor switch to button if either side has come off you have to re attach it just cut off 1/4 inch of the tube before you do. that will make it fit tighter
Anonymous
  • 248 Answers
  • Posted on Oct 03, 2009
SOURCE: Just drained jacuzzi hot tub and replaced
bleed pump check fuses and connections
Regarding a 30x60 indoor jetted tub (Jacuzzi). When I push the on/off button, the pump slows down but then a few minutes later starts again on its own when there is no water. Any idea what is going
IF that is the one I recall, the switch is not connected to the tub. When you press the button, it sends air pressure to the switch under the tub to activate it;. You need to check the tubing and the switch
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
1helpful
My Jacuzzi Tub won't start
Try compressed air through the system,careful not to use too much pressure. Also you may use another water pump to push water through system and free up the motor. The easiest thing may be to get a new motor though.
Dec 10, 2012 • Home
1helpful
3answers
When I push the button on my american standard jacuzzi tub I hear the hum of the motor but jets don't come on
In my case I took the motor out and used a screw driver to turn the impeller in the front of the pump and the fins inthe back. Put it back together and it worked. I then used 2 tablesoons of dishwashing detergent and 1/2 cup bleach and ran it for 20 minutes to clean and degrease the impellers
1helpful
I just bought a home that has a 3 year old white Jacuzzi Cetra H526 000 Whirlpool Jetted tub. It was not well maintained. I need 4 new Thermo Pro Jets, 2 Accu Pro Lumbar Jets, a square grille,and a product...
Jacuzzi Cetra Comfort Bath home page:
http://www.jacuzzi.com/baths/options/models/cetra
Installation and Operating Instructions:
http://www.jacuzzi.com/admin/files/files/4cfd8269-e7b0-4286-9908-7b9743.pdf
For replacement parts your best bet is to you use the on-line dealer locator:
http://www.jacuzzi.com/baths/pages/dealer-locator
or you can shop on-line from one of their authorized retailers; however did not see any of the parts you are looking for at the sites I checked:
http://www.jacuzzi.com/baths/pages/buy-online
Our jacuzzi is almost regular tub and has tow metal buttons, one on the top/edge and the other near jet mouse at the middle level of bath tub. We have not used our jacuzzi for 10 months. Even we only use...
The metal button on the top of the tub is used to turn the tub on/off. the metal button you see in the middle of the tub above one of the jets is the low water sensor.
the water has to be above that metal tab, you have to be in the tub and then touch the metal button on the top of the tub to turn it on.
this system uses the electrical current from our bodies to complete the circuitry and turn it all on and off.
Feb 12, 2011 • Home
1helpful
We've had a whirlpool tub with jets for 2 years. About a year ago, the jets stopped working--i.e. you push the button and nothing. Whe have it hooked up to one of those cool water circulator things that...
5helpful
Black come out the jets when first operating them
Didn't fully drain at the end of last year, that gunk was mold, rust and gunk that's been sitting in the piping since last year. Not really a problem just remember to take a closer look at the plumbing on your tub next year and get all of the possible places that water may hold drained completely.
Jacuzzi
Top Jacuzzi Home Experts
john h
Gene Lawson
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
