Is the cooling fan running in the oven? Does it also continue to run when the oven controls are turned off to let the oven cool down?
There are ventilation grills below each door on the oven. You can see these when the doors are fully open, just look under each door to see if they are clear and not blocked up.
Is the cooling fan running in the background? It should stay on about 5 to 10 mins after any of the ovens/grill are turned off. (When the bottom oven is on, there should be a blast of warm air coming out of the oven along the top edge of the bottom oven door. If the cooling fan is not running, or running slow, this will cause the oven to overheat and cause the thermal cutouts to overide everything). Also when you say the grill does not get red hot, is this both grills or just the large or small one?
